my car isnt runnin too good....
Old Nov 29, 2004 | 02:17 PM
PKaiser's Avatar
Ok to start it off, i have the 0304(KS) and the 1008(EVAP). My car was runnin fine with both these codes. Ive had the 0304 code for a while, it didnt really bogg me down too much, just gave me crappy gas milage. I just recently got the 1008 code, it was running fine with this code for about a month. Now all the sudden, my car stutters when med-heavy throttle is applied, so im guessing it has something to do with the knock sensor. Im not sure tho because im not too sure what the symptoms of a bad KS are, because ive never experienced one with any other car.
basically, whenever i want to accelerate it feels like im riding a horse. Its very un-smooth because of the sudden drops of RPMs. Do you all think the KS this is the problem?
I plan on checking my PCV valve, throttle body, and i guess my EGR system. anything else i should check?
Another question i have is, is the 1008 code really anything to worry about?I pretty much didnt care when i saw it.
Old Nov 29, 2004 | 02:37 PM
NmexMAX's Avatar
dot dot dot ...
Sounds more MAF related.
After you clean those items you listed, let us know what happens, and also after you change out the items concerning your codes.
Old Nov 29, 2004 | 02:55 PM
Ant96GLE's Avatar
What year is your Maxima? If its a 99, it may be bad coil packs.
Old Nov 30, 2004 | 01:40 PM
PKaiser's Avatar
it is a 96
Old Nov 30, 2004 | 02:27 PM
PKaiser's Avatar
ok i checked the ECU again and i didnt get any other codes. so i guess MAF is not the problem
Old Nov 30, 2004 | 06:38 PM
thisisausername's Avatar
I got the evap minor leak code once(turns out we forgot to connect a vacuum hose), and during that time car ran bad and had trouble idling.
MikesChevelle
Nov 23, 2024 11:17 AM
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
Balkins
Aug 12, 2015 06:39 AM
altome15
Aug 10, 2015 07:05 PM
