oil leaking from where flywheel/clutch sit help
Old Nov 30, 2004 | 12:07 AM
mad-max98's Avatar
what is that resulting from,,btw oil leaked through a crack in my tranny and was making alot of grinding noise i welded the hole now oil leaks between the engine and tranny
Old Nov 30, 2004 | 12:27 AM
Batxel's Avatar
blah
usually the leaking inbetween the engine and tranny is a sign to replace the rear main seal. But I don't think that's what it is in your case. My car was dropping about a quart of oil every 3,000 mi and I noticed a leak between the tranny and engine. I changed my tranny oil and the correct amount was in there. Eventually the clutch died and I had the rear main seal replaced as recomended by my mechanic now my engine oil doesn't go anywhere.
Old Nov 30, 2004 | 02:23 AM
mad-max98's Avatar
oh itssn't engine oil it's gear oil
Old Nov 30, 2004 | 05:11 AM
Stephen Max's Avatar
Could be the input shaft seal. A leak there would end result in oil at the engine/tranny interface.
Old Nov 30, 2004 | 12:08 PM
mad-max98's Avatar
is that on the tranny side or engine side i'm assuming it's the tranny cuz of the grinding gears
Old Dec 1, 2004 | 06:15 PM
mad-max98's Avatar
does anybody know how much that seal is
captchaos
Mar 15, 2016 12:18 PM
JoshG
51
Sep 21, 2015 10:41 PM
RWCreative
Sep 21, 2015 11:01 AM
pears
Sep 18, 2015 05:25 AM
ag90fox
Sep 9, 2015 12:22 PM
