emerg. brake light always on
Old Dec 1, 2004 | 12:31 PM
radicht's Avatar
My emergency brake light on the instrument panel is always lit, even when I take off the emergency brake. What are the order of things that I should troubleshoot to remedy problem? Thanks.
Old Dec 1, 2004 | 12:34 PM
4DRSpeed's Avatar
Project Ruby......
Pop the hood check your brake fluid if low fill up ebrake light goes off your done.
Read owners manual!
Old Dec 1, 2004 | 12:43 PM
Conrad283's Avatar
I need a truck
Check the brake fluid and if that doesn't work then take off the center console. There's a sensor that is supposed to be hooked up to the brake so that the light goes on only when the e-brake is up. Check that bad boy also.
Old Dec 1, 2004 | 12:45 PM
radicht's Avatar
thanks guys, i appreciate it. I don't have an owner's manual, so I really should get one. Sorry for the stupid questions.
Like they say...There are no stupid questions, just stupid people.
Old Dec 1, 2004 | 01:26 PM
Pappa Grande's Avatar
Do what everyone else says. If you notice your battery light coming on too, it probably means your alternator is shot.
Old Dec 1, 2004 | 01:33 PM
bigleman's Avatar
Advocatus Diaboli
Actually you guys are missing the easiest answer...
You need new brake pads.
The light comes on when the fluid is low.
The fluid is low because there is a leak or you pads are getting worn out...
Old Dec 1, 2004 | 04:35 PM
MaximaSE96's Avatar
Maxima Owner
u know mine have been on for over 2 years
Old Dec 1, 2004 | 04:40 PM
aznprid972's Avatar
hey i just had the same exact problem today too! woke up and after about 10 feet of driving, i thought i left the ebrake down because the light was still on. pulled the ebrake up and down and it still didnt turn off. i later filled it up with brake fluid and tada.. problem fixed
Old Dec 1, 2004 | 05:25 PM
Wills98MaxSE's Avatar
1 of few unmodded 4G Maxs
check your e-brake cable as well
Old Dec 1, 2004 | 06:53 PM
kcryan's Avatar
it was 3 days ago for me....... but i think i just have a leak
Old Dec 1, 2004 | 07:49 PM
bigleman's Avatar
Advocatus Diaboli
you can't just keep adding brake fluid!!! You'll end up being full of fluid and have no pads left!! You can't stop on brake fluid alone...
Old Dec 2, 2004 | 05:38 AM
4DRSpeed's Avatar
Project Ruby......
The easiest answer is to fill the fluid then change your pads. You can get cheap fluid at AutoZone for like $3. But while pouring some cheap fluid into your master cylinder for the time being you should definetly be ordering new pads.
I had this happen too me as well, the light came on and my fluid was low. But it was because my brakes were so shot and the pads were basically gone. Replaced everything about 3 weeks ago, gotta love Brembos and MM Pads.
Old Dec 2, 2004 | 09:43 AM
KCMaxima98's Avatar
Mine came on for a couple of days and I figured that I probably needed new brakes. A couple of days later the battery light came on with it though....Alternator went bad on me. I hope this isn't your problem but I wanted to point out that possibility.
mvm062
Nov 30, 2020 09:00 AM
MaxLife17
Jun 27, 2019 01:37 PM
Maxima30
Sep 7, 2015 06:13 PM
A32goldylocks
Sep 2, 2015 06:39 AM
