Rear Window Off Track....Please Help
Figured it was a matter of time something would go wrong after buying a 10 year old car but hopefully this is an easy fix.
I had rolled down my rear windows a bit this morning on the way to work. When I went to roll them back up, I heard a light "pop" and my driver's side rear window wouldn't roll up. When I got to work, I checked it out and I can raise/lower the window just using my hands. When I press the button, I can hear the mechanism going up/down but obviously, it's not catching the window on the way up.
I have some expensive stereo stuff in the car and it's getting pretty cold out as well. Can someone please tell me if this is a simple fix and if so, what exactly are the steps to fixing this. I'd really like to do this after work today so any help would be much appreciated.
Car is 1995 SE.
Car is 1995 SE.
There's a piece of plastic in there that mates between the window regulator pulley system, and the window. That plastic snapped.
Either buy a new window regulator (sometimes $40 or $50 on ebay), or go in there are plastic weld (epoxy) that piece of plastic that broke. If you go the cheaper and quicker route (which i did), I used some two-part epoxy that was made for white plastic welding (the epoxy wasn't clear, it was white and cloudy). I also thoroughly cleaned the two surfaces of the two pieces of plastic that broke with alcohol. I also used atleast half of the $5 epoxy I bought. I really built up the bond, so it doesn't fracture again.
markevans999
09-10-2015 04:29 PM
ef9
09-05-2015 11:18 PM
