JWT ECU for 95-99 Maximas: Is this how it shakes out?
Old Dec 2, 2004 | 01:11 PM
MaxxAddict's Avatar
Ok, I'm talkin about JWT modified ECU's ONLY. (cuz that is the company I'd go with). Is this how the ECU predicament shapes up?
95 Maxima: ECU can be reprogrammed
96 Maxima: ECU can be reprogrammed
97 Maxima: Need to send in 95 or 96 ECU to be reprogrammed and take out the stock ECU.
98 Maxima: Need to send in 95 or 96 ECU to be reprogrammed and take out the stock ECU. CEL comes on for rear O2 sensor malfunction
99 Maxima: No hope whatsoever.
Ok, if the above data is correct, is it worth it to send in a 95 or 96 ECU for my 98 Max 5speed? Who has done this? Is the CEL the only drawback?
Old Dec 2, 2004 | 01:14 PM
Jason R's Avatar
aka UNCDooD
There is hope for the 99. you just need to do a little modifying to the wiring harness.
MardiGrasMax is the only person I know right off the top of my head that is running a JWT ecu in his '98.
Old Dec 2, 2004 | 01:24 PM
Big_Ham's Avatar
MaximaFreak
CEL in '98 can be avoided by buying the different rear O2 sensor used in the 4.0 gen instead of the one that came in the 4.5 gen. I believe the 4.5 gen is 3 wire and the 4.0 gen is 4 wire. I am not positive about wires and such, but I do know that the reason the rear O2 sensor light shows is because they're completely different from 4.0 to 4.5 gen.
Old Dec 2, 2004 | 01:34 PM
MaxxAddict's Avatar
Oh. really? How difficult is the re-wiring of the 4th gen O2 sensor? Is it a DIY operation?
If that's all it takes (get a 95-96 ECU and rewire a 4th gen rear O2 sensor), why does it seem like ppl always crying about how there is no hope for 1998s (or even 1999s for that matter)?? Is it because no one wants to go to the junkyard and end up installing an older ECU?
Old Dec 2, 2004 | 01:50 PM
Big_Ham's Avatar
MaximaFreak
Because this URL should be www.whining-babys-who-put-down-everyones-rides-and-ideas.org.
The biggest lesson I have learned here is that anything is possible with enough money or enough work. Unfortunately, because this is a forum, anyone can post and those intelligent posts get buried beneath all the BS newbies and know-it-all's spew.
Old Dec 2, 2004 | 02:02 PM
chuckie311's Avatar
you should PM eng92 he can tell you all about it he took care of his CEL light
eng92's Avatar
For a 98, use this:
http://forums.maxima.org/showthread.php?t=350138
I have been running a 96 ecu in my 98 for a several weeks now with no codes
PM me if you have any ?
For a 99, it will take some terminal re-locating in the ecu harness connector to get the engine to run. I have the pin-outs for a 99 to a 96. You will get a series of EVAP and EGR related codes because the systems are different. Also, the harness rewiring will probably only work for a manual tranny. The TCM in an auto is completely different between 96 and 99.
Mahmuth
Aug 16, 2024 08:23 PM
litch
123
Jan 4, 2024 07:01 PM
gigabyte
Jan 6, 2017 06:05 PM
Need help
23
Oct 2, 2015 08:56 AM
dshinn
Sep 26, 2015 08:07 PM
