Alarm remote programming messed up
Old Dec 3, 2004 | 04:47 PM
exiva's Avatar
argh! i bought a new remote for my moms 97 maxima off eBay and it came with directions -
get inside the car, close the door
using lock/unlock button in the car lock the car
insert key into ignition, take out completely
repeat step 3 untill the turn signals on the dash blink
once the signals blink, turn the key to the on position (this is where i messed up)
her car has a replaced ignition from nissan since it was faulty, and i now have 2 sets of keys (door, and ignition) and i used the wrong key (door) to start the procedure... and i unlocked the doors using the switch in the arm rest to get out... fustrated, and went inside and realized i used the wrong key. now i cant get the turn signals to blink. my origional remote doesnt work now and when i put the car into ACC and hit the button, the lights on the dash flash. (oh also, the little switch on the door that triggers the alarm, and the interior lights is broken.... (its not my car and it got broken from a minor accident))
Old Dec 3, 2004 | 04:57 PM
Igobuk's Avatar
There are more detailed directions in the FAQ's. I bought some the other day too.
http://forums.maxima.org/showthread.php?t=254238&page=2
It'll work, just make sure you have the right key for the ignition this time and you'll be fine.
Old Dec 3, 2004 | 05:20 PM
exiva's Avatar
i think it wont work because its stuck in program mode (due to the drivers side door not being "open") because of that switch.
Old Dec 3, 2004 | 06:15 PM
Igobuk's Avatar
? You can't open the driver's side door ?
As long as you have...
1. Ignition key
2. Driver door power door lock and manual lock switches work
3. OEM Remote(s)
4. Driver door opens
There's no reason they won't work.
Old Dec 3, 2004 | 07:26 PM
exiva's Avatar
the door opens, but you know that rubber switch on the bottom of the doorjam that triggers the lights and alarm.... is stuck in the down position
Old Dec 3, 2004 | 07:33 PM
Igobuk's Avatar
Swap it with the switch from the other front door. The rear door switches are different so you need the passenger side front door switch.
Old Dec 3, 2004 | 07:42 PM
exiva's Avatar
got any info on doing this? well, id rather both switches work.... but i guess for the time being.. so i can get the alarm working again
Old Dec 3, 2004 | 07:55 PM
Igobuk's Avatar
It's held in by 1 screw. Get a philips head screwdriver, take out the 1 screw and pull it out. Unplug it and replace with switch from passenger side.
Done.
Old Dec 3, 2004 | 08:43 PM
exiva's Avatar
unplug? got a picture or something?
Old Dec 3, 2004 | 08:45 PM
Igobuk's Avatar
Are you serious ?
You really don't need a picture. Just go take the screw out and pull out the switch. You will see a plug attached to it. Unplug it. Replace with passenger side switch. Program your remotes.
Old Dec 3, 2004 | 09:15 PM
exiva's Avatar
alright, sorry for the n00b questions... ive never worked on a car before.
know where i can pickup a new switch cheap?
Old Dec 3, 2004 | 09:30 PM
Igobuk's Avatar
You could try a local junkyard or an org member that might be parting out his car.
Check the classified section of this forum to see if anyone is parting out a Max and see if he'll send them to you with anything else you might need.
I needed two of them about a month ago and an org member was parting out his car and I got the switches along with some other stuff real cheap.
litch
123
Jan 4, 2024 07:01 PM
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
zzznightmarezz
Sep 21, 2015 06:32 PM
flu2000
Sep 14, 2015 12:34 PM
intimidator
Sep 5, 2015 07:23 PM
