stock remote no longer works
Old Dec 5, 2004 | 10:57 PM
Vlasic's Avatar
RaWr!!! ('''_(o_O)_''')
my stock keyless entry remote BARELY works now. the trunk, unlock and panic button no longer work. sometimes they will work, but i gotta hold the button down for atleast 30 seconds. the lock button does work, but i gotta hold it down for about 5-7 seconds. i replaced the bettery and it did nothing. luckly i have an aftermarket alarm...but that is also failing so i gota use my aftermarket remote to unlock the doors, and use the stock one to lock the doors.
do the stock remotes tend to break? could getting a new remote fix this problem or is it a problem with the actual system?
Old Dec 6, 2004 | 06:12 AM
MilesA's Avatar
The stock remotes do tend to wear out after years and years of use. It is the buttons and electrical contacts under them that wear. You can buy a replacement from Ebay for $15-20. Don't pay the inflated prices from the dealer.
Old Dec 6, 2004 | 06:20 AM
Max96GLE's Avatar
Before you do that, change the battery in the remote.
Old Dec 6, 2004 | 06:24 AM
MilesA's Avatar
Originally Posted by 96stillen_max
...i replaced the bettery and it did nothing...
He tried that already.
Old Dec 6, 2004 | 07:34 AM
Igobuk's Avatar
You can also try opening the remote and cleaning it out. Get some rubbing alcohol and cotton ***** and clean off all the contacts until the cotton ***** don't get dirty anymore.
I had my remote fall into a swimming pool. I dried it off but it worked crappy. I had to hold buttons down, range sucked, etc. I opened it up, cleaned out all the lint and the contacts. The inside of the remote was actually bluish like the pool. After I cleaned it up, it worked like new.
Old Dec 6, 2004 | 09:31 AM
MaximaSE96's Avatar
Maxima Owner
autozone now sells them too. but not much cheaper than the dealer
Old Dec 6, 2004 | 10:20 AM
Vlasic's Avatar
thanks guys. ill try and cleaning it and if that doesnt work ill just buy another one.
ah2002
Mar 9, 2016 01:42 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
kenc15
Aug 5, 2015 08:29 AM
