How to tell my engine is knocking?
Old Dec 14, 2004 | 11:42 AM
Y-MAX's Avatar
I put in the resistor replacement for KS (untill the weather gets better) and my 95 SE has been running great-- good gas milage, restored power, etc. But after reading some thread, I started to worry about the engine knocking. My question is, what kind of sound is a engine knock exactly, loud? faint? metallic? thump? consistant? occasionally? Any other common symptons associated with engine knocking, like steering wheel vibration at idle (that's what I have but it could be a bad engine mount)?
Thanks in advance.
Old Dec 14, 2004 | 01:54 PM
jbreit's Avatar
Knocking will create a very distinct very audible rattle. It will be a metallic sound....and is basicly the piston slamming around in the bore and the connecting rod wrist pins/bearings making metal to metal contact with other parts.
I don't in general condone your temporary band-aid, so recommend you stick to good gas in the meantime. The knock sensor is to protect the engine from bad gas, or excessive over use.
Old Dec 14, 2004 | 02:27 PM
Y-MAX's Avatar
Thanks man. That put my mind at ease.
I know the resistor is a temp fix. Just ordered a new KS and waiting for the weather to get better so that I can put it on.
By the way, anyone know a good source for a new engine mount? I have been seaching ebay and GD for a month now. Nothing. I have a slight vibration idling and sloppy take-off(clutch pedel shakes and took a full second to engage first gear, all other gears super smooth at any speed) ao I guess it's probably the mount.
Old Dec 14, 2004 | 03:02 PM
exit10's Avatar
it could be i have this too... umm
ballerchris510
Sep 23, 2015 08:46 PM
ac max 92
Sep 17, 2015 07:35 AM
ballerchris510
Sep 11, 2015 05:29 PM
