Car ideling at like 550???
Dec 15, 2004 | 12:56 PM
sorry such a stupid thread but please bear with me-after the car warms up for a few minutes it then idles at around 550-600 it runs so smooth but seems a lil low. how can i increase it to like 700 or so. Isnt the normal idle around 700? let me kno thanks
Dec 15, 2004 | 01:08 PM
http://home.earthlink.net/~maxfaq/
Click on 'Maintenance' off to the left, then select '4th gen idle speed' in the right field and it will give you directions to adjust your idle speed.
Dec 15, 2004 | 01:13 PM
My car also idles that low once warmed up, but I've never had any problems with it so I see no need to adjust it.
-Cyrus
Dec 15, 2004 | 01:17 PM
thanks a lot -will do it 2m -but j/w what is everyone elses ideling at? is 550 normal for a warmed up car?
Dec 15, 2004 | 01:22 PM
im at about 600-650
Dec 15, 2004 | 01:27 PM
According to my haynes...
1995
stick->550-650
auto->600-700
1996 and later
stick->525-625
auto->600-700
Dec 15, 2004 | 04:44 PM
Yea thats pretty normal.. I idle at about 550 to 600 all the time...
Dec 15, 2004 | 06:03 PM
Auto.
I idle that low also. No shakes.
Dec 15, 2004 | 07:57 PM
Hey try doing the throttle body cleaning as explained at http://www.motorvate.ca/mvp.php.
It helped my rough idling.
Dec 15, 2004 | 08:12 PM
Are you talking about idling in drive or in park?
Dec 15, 2004 | 08:21 PM
drive and yea i did clean my tb-the car isnt rough ideling i just thought is is low -well it seems a lil rough but it is also 20 degrees outside so that can be it also
Dec 15, 2004 | 09:08 PM
hey, guys, first post here... don't know if it was answered before but search isn't working for me.. so a quick question...
when i start my car, the initial ignition revs it over 1000, but then it drops quickly and stalls. The only way i can get it to idle is the rev it a little bit, very lightly, nothing over 1500 w/the throttle for a few seconds, then it idles around 1000 for a little till it warms up and falls to around 600. It only stalls when i start it up in the morning to go to school, or if it's been stationary for 5 or more hours. Do you guys think it's throttle body also?
ChiShi
*edit, 96 GXE auto
I looked at the TSB, but was wonering if there was anything DIY fix and see if it worked. Like the TSB says, my car has difficulty starting after some ours of cooling or overnight at cold temps. It says it's running overrich fuel during cranking so i gotta keep the cranking period extended to get it started. Is there anyway i can verify/fix this?
Dec 16, 2004 | 03:31 AM
you should never need to adjust the idle speed. if your idle speed is incorrect, look else where to solve your problem. adjusting the idle speed is just a quick fix.
