Stalling
Old Dec 19, 2004 | 10:41 AM
toly101's Avatar
Stalling
I have a '97 maxima se. It stalls on me all the time. i'll be driving and it will stall. but i can put the car in neutral, while in motion, and start it again.
i first thought it might be the battery or something, so i changed the battery, and the car started running fine. for a few weeks, until the same thing happened again.
so i went to the mechanics, and they hooked it up to there computers and did all the diagnostics. and found nothing wrong with the car. they reset my computer. and said everything would be fine now. but that didnt do a thing, it started happening again, ten minutes after i left the shop.
i dont know what it is. i'm thinking maybe the alternator, or a short in the wiring. someone please help.
Old Dec 19, 2004 | 10:51 AM
njmaxseltd's Avatar
Start by cleaning the throttle body and the IACV valve.
Old Dec 19, 2004 | 04:34 PM
maxima_kid's Avatar
wat do you mean by stall. is it when ur just at idle at a stop sign or when you let go of a gear from higher rpm? pop starting makes it easier but might kill ur starter faster.
Old Dec 19, 2004 | 09:47 PM
toly101's Avatar
the engine just dies, when every it pleases. while in motion or while at a stand still.
Old Dec 19, 2004 | 10:08 PM
KNYFE's Avatar
I was having similar probs with my 96 I30. It was the engine coolant temp. sensor. Good luck!!!
Old Dec 20, 2004 | 06:23 AM
smackdownGTR's Avatar
Would a bad engine coolant temp sensor throw codes? After reading all these threads regarding hard to start, I'm thinking mine could be that sensor. I'm not getting any codes, but ewvery time when the car is cold I need to pump the gas peddle a few times so the engine turns over. When the car is warm it starts perfectly. There definitely isn't anything wrong with the starter.
Old Dec 20, 2004 | 07:05 AM
toly101's Avatar
is it possible to just replace the sensor?
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
sake1bs
Sep 19, 2015 09:32 PM
97_GXE
Sep 15, 2015 06:47 AM
