can't take off fuel filter
Old Dec 19, 2004 | 02:53 PM
kv2's Avatar
kv2
wtf is wrong with my car. I can't take the hoses off the fuel filter. I cranked the engine maybe 10 times already and took off the clamps alrady. I tried pullin it off for like an hour already. what did you guys do.
Old Dec 19, 2004 | 02:55 PM
Terran's Avatar
Just keep trying...it'll come off. You might try a screw driver to sort of push the hose off rather than pulling it off.
Old Dec 19, 2004 | 02:57 PM
NmexMAX's Avatar
dot dot dot ...
Squeeze the end hose barbs gently to reduce the outside diameter with some pliers to crush it so it slides off easier.
Old Dec 19, 2004 | 02:58 PM
I30tMikeD's Avatar
twist, don't pull
Old Dec 19, 2004 | 03:21 PM
njmaxseltd's Avatar
Originally Posted by I30tMikeD
twist, don't pull
Twist and pull, also it helps if the hoses and engine compartment are warm like after the engine is shut down for about an hour. The warm rubber is softer and makes the job just a little easier sometimes. Put some lube on the ends of the new filter so the hoses slide on easier. That might also help them release next time you change the filter.
Old Dec 19, 2004 | 03:28 PM
Ant96GLE's Avatar
Your not trying hard enough, get some needle nose and twist it off
Old Dec 19, 2004 | 03:49 PM
BEJAY1's Avatar
Conecarver
If after you're ready to give up you could always cut the hose if you've got an extra inch of slack. Or buy some extra hose too.
Old Dec 19, 2004 | 04:08 PM
kv2's Avatar
kv2
this is kinda wierd cause after trying to pry it off and having a bubble form on my finger now... i cranked the car again and it sounded like it was struggling to start, like it was about to, and then not, and about to, then not. it's like pressure builded up or somethin ???
Old Dec 19, 2004 | 06:18 PM
GoalieKeg's Avatar
twist, don't pull
EXACTLY!
Use a pair of robogrips, or any needle nose pliers will work.
Old Dec 19, 2004 | 07:01 PM
madmax96's Avatar
i cut my line on the bottom cause i couldnt get it of.then i moved the filter up for i can get to it better next time.you can get more hose at auto parts store and alll you need to do this.
Old Dec 19, 2004 | 07:49 PM
Tyrexx's Avatar
twist twist twist, use a soft pliars of pliars with tape or somthing. dont damage the hoses
Old Dec 19, 2004 | 08:34 PM
Greg1997se's Avatar
there is a little lip on the filter so make sure that the clamp is slid back pretty far onto the hose before you start twisting and turning.
Old Dec 20, 2004 | 12:44 PM
kv2's Avatar
kv2
today is another bright and sunny day. and i'm gonna make another go at it.
i don't think i have any pliers so gonna have to use my good ol hands again.
I read in one of the threads about opening up the gas tank cap? what will that do in terms of pressure within the lines? and is cranking the engine numerous times for 5 seconds, bad for your engine in any way? it sure doesn't sound good for it...
thanks.
Old Dec 20, 2004 | 01:12 PM
twiggy144's Avatar
Dont pull on the hose. They act as a chinese finger lock. The more you pull, the more the hose will grab on the filter spout. You have to push on it. You really need pliers to first twist the hose right and left to break the seal, and second to push on the hose.
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
Forge277
Jun 13, 2016 09:26 PM
Justin Kroll
Oct 1, 2015 07:03 PM
