Power door locks relock
Having an intermittent problem with power door locks relocking on my 97 Max. I remotely unlock the door and it will lock before I can open it. As well, the doors locks will lock while I am driving sometimes. I can hear a clicking sound coming form the dash when this occurs. The problem seems to be less likely to occur if I turn the domelight to off for some reason.
Anyone seen this behavoiur before?
Thanks Hrap, very likely it's the battery that is slowly going. I was told that before winter by a mechanic but the car has had no problems cranking until today when it was really cold. You had the exact same symtoms?
I have a '98 GXE with power doorlocks (but not remote access). I think the remote part probably doesn't matter in this case. The symptom I had was that immediately upon unlocking the door it would relock - in a fraction of a second. It was actually a challenge to unlock the door and get it opened. I didn't have any symptoms while the car was running, and don't recall any clicking from the dashboard. But at a minimum I'd check the battery to see if it is the likely culprit. (And, I had the problem twice, in different years, with two different batteries - mine was one of the '98s with a flaky alternator and it slooowwwly ruined the batteries).
