replaced my clutch with Exedy stage 1.....hard to put it in gear?!
Old Dec 21, 2004 | 08:23 AM
Jonny98max's Avatar
ive been driving on my new clutch for about 1000 miles now.....one thing that i have noticed is that is it really hard to downshift to first gear.....i have to like force it into gear......i am just running on some standard Gl-4 tranny oil....i was wondering if its my tranny oil that is causing this? it feels really notchy....im not sure if its the clutch or the oil or both?
Old Dec 21, 2004 | 08:58 AM
95stillenmax's Avatar
I had this same problem with a spec clutch and what is was is a prong on the pressure plate was bent not even visable by eye so that is most likely your problem
Old Dec 22, 2004 | 09:20 PM
NISMOPower's Avatar
what can cause that????
Chris
Old Dec 22, 2004 | 09:26 PM
matty's Avatar
Chris
Put in some RedLine GL-4 Tranny Oil...most of that will go away
-matt
Old Dec 23, 2004 | 06:12 AM
95CustomMaxima's Avatar
Check your clutch fluid, and you could try bleeding the clutch.
-Nick
Old Dec 23, 2004 | 06:26 AM
killcrap's Avatar
I'm actually quite pleasant until I'm awake
down shifting = bad for clutch
Old Dec 23, 2004 | 07:32 AM
sterlingmaxima's Avatar
downshifting is not bad for your clutch unless you dont match rpms and try to avoid downshifting into first maybe your clutch is not alligned just right to.
Old Dec 23, 2004 | 10:00 AM
Batxel's Avatar
blah
CorollaULEV
30
Aug 9, 2021 08:11 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
vanebecker
Aug 17, 2015 08:24 PM
carlosvq30
Aug 17, 2015 11:32 AM
sc10692
Aug 9, 2015 09:37 AM
