very weird hesitation, NEED HELP!
Old Dec 27, 2004 | 12:39 PM
MaximA StyLeZ's Avatar
driving the max today, and put it into 1st and drive normally until, i suddenly accelerate a little more and my car just hesitates, jumping back and forth (sort of like when your learning to drive stick) then i have to quickly shift into second and same thing happens when i give it more gas. the car just jumps instead of smoothly accelerating. No problem in third or fourth. This is bothering me alot, so if any1 knows what this is and how to fix it , PLEASE HELP
Thanks guys
Old Dec 27, 2004 | 12:42 PM
tavarish's Avatar
fwd gone rwd cr00
sounds like a clutch problem, but what do i know, i'm an auto guy
Old Dec 27, 2004 | 01:07 PM
clutch is brand new, def. not the clutch
Old Dec 27, 2004 | 03:44 PM
exit10's Avatar
i have this same issue but it doesnt seem as bad. does it go away after the car is warm or does it constently do this?
Old Dec 27, 2004 | 04:12 PM
96ItaliaSE's Avatar
il massimi bassi
I Know exactly what it is bro its a bad ignition coil. what happening is the original coils get cracks in them around 100k they start to misfire and cause your car to misfire/hesitate/stall/float i know what ur talking about its like the divers ed guy hitting the brakes right in the middle of the driving lesson and u njust start bucking.
coils are 60 bux a piece at autozone and I reccomend replacing all 6 if you can swing the cash.
Old Jan 3, 2005 | 08:39 PM
Shift_Power's Avatar
True...same prob with me, it was the coils. Do you drive a 99 by chance?
Old Jan 3, 2005 | 08:48 PM
CystumMax's Avatar
Well I should wrap this up before I start to ramble.
The answer is on the left hand side....
MaximA StyLeZ MaximA StyLeZ is offline
Maxima Enthusiast
Car: 1996 Pebble Beige SE
Old Jan 3, 2005 | 09:11 PM
well guys i just changed the fuel filter and added techron chevron, and it went away. But it went away be4 adding this stuff, it was a on/off kinda thing. Hopefully it just stays away.
Old Jan 4, 2005 | 12:33 AM
maxtuner96's Avatar
Thanks guys
I've got the same problem with my 96 5spd. I hope after replacing the fuel filter and the knock sensor this week the problem would go away. If I do have to replace my ignition coils, how would I know which one is going bad? $300 is alot to spend on coils...i'ttl set me back on mods for almost a month.
Old Jan 4, 2005 | 09:16 AM
ChristheNite
Yeah I had the same problem in my 1996 5spd too. Weird - I changed my fuel filter to the 300zx filter and i had 2 codes for my o2's show up. Changed those and everything seems to be fine - all I can figure is the car's starving for gas, and it was your old clogged fuel filter.
HerpDerp1919
Sep 29, 2015 02:02 PM
JoshG
51
Sep 21, 2015 10:41 PM
jchronis2552
Sep 21, 2015 05:52 AM
bennuss
Sep 11, 2015 05:55 AM
trungg86
Sep 4, 2015 04:58 AM
