Heated Seats
Old Dec 27, 2004 | 05:49 PM
acmax95's Avatar
Heated Seats
I have a 95 Max with heated seats. Buti dont believe they work. When i flip the switch the switches don't light up. The fuses are good. is there anything else i can check.
One switch is all sticky. i think the previous owner spilt coke on the center console. Where can i buy some new switches. thanks
Old Dec 27, 2004 | 06:07 PM
madmax96's Avatar
try to take them apart and clean them
Old Dec 27, 2004 | 06:48 PM
unixadm's Avatar
I've got the same thing going on. It's one of those mind over matter things. I swear some days it seems like it's working without the light being on.. other days I don't notice any heat. I checked my fuse too and it's just fine. I have a feeling that Soda may be the root cause of the problem. Maybe I'll yank the switches out tomorrow and see what I can find. I know it's not the seats because I swapped in some 99 I30T seats and nothing changed.
Old Dec 27, 2004 | 07:29 PM
adithius's Avatar
You can take out your old switches and replace the light. LED would be best. Get the parts from Radio Shack.
Or I'm sure you'l find someone to sell you new ones.
Old Dec 27, 2004 | 11:40 PM
newborn1281's Avatar
take them appart and clean then i hgad this problem cleaned they still didnt light up but then in 2 days they started working miracle
Old Dec 28, 2004 | 03:51 AM
JSMax's Avatar
Sold
the light only tells you that they are on. If your light is burnt out, the heated seats should still work. Mine did for like 2 years. I finally changed the bulb and had a hell of a time trying to find that bulb. Nissan dosen't even have a part number for it??? New switches are like 35 bucks or something. Go that route if you think the switch has been damaged due to a liquid spill.
Old Dec 28, 2004 | 05:15 AM
JoeB
My bulbs where burned out but my heated seats still worked. It takes a while for them to get warm. I replaced my light bulbs with 3mm 5000 mcd white LED's. I think there is a group deal somewhere or you can just buy them on E-bay (Cheap). Radio Shack has ridiculus prices on LED's . They wanted $5 for 1 white 5mm. If your switch is dirty inside it should be easy to clean while you have it apart.
Old Dec 28, 2004 | 07:09 AM
konak85's Avatar
the lights on mine don't work but you can really feel the heat on your cheeks.
Old Dec 28, 2004 | 07:40 AM
Bigwalt304's Avatar
Im sorry this is a little off topic but, if im putting power/heated seats into my max which didnt have heated or power seats before they should hook right up. right?
Old Dec 28, 2004 | 08:30 PM
TJ_Max's Avatar
Paradox Systems Vendor
to be honest, i have ablack max, and i disabled my heated seated seats, i felt like i was peeing on myself when they were on, lol...but i have switches there for looks MAYBE we can just swap, im sure my leds work in the switches i got....i really dont need working ones...but clean that soda out first...
Old Dec 28, 2004 | 08:31 PM
TJ_Max's Avatar
and bigwalt, i thnk u need the power connectors for the seats, im not sure at all though...dont think u can just throw em into the mix....could be wrong though....
Old Dec 29, 2004 | 09:06 PM
Bigwalt304's Avatar
Can Someone Confirm that the seats arent plug n play?? i Just bought some. And remember reading somewhere that they are already pre wired.
Old Dec 31, 2004 | 04:55 PM
bigd480's Avatar
i have the same soda stickiness but the seats and lights both still work so I haven't tried to take them apart - good luck
Old Sep 27, 2010 | 01:04 PM
dercody's Avatar
Ok, so, what fuses are for the heated seats?? I dont see any marked specifically for them. I am new to Maxima's I would presume that they have combined the fuses for different functions, so it would not surprise that they put the heated seats in with something else. I have looked at the fuses (unless there are some i dont know about) and only found 1 that was blown which was the lighter fuse. btw, car is a 95, with leather seats and there are two switches in the center console.
Old Sep 27, 2010 | 01:49 PM
ColombianMax's Avatar
Last I remember, heated seats have their own independent circuit
Old Sep 27, 2010 | 04:26 PM
dercody's Avatar
ok, cool, so where would it be?? don't seem to see a fuse marked for the seats, not even for the electric functions
Old Sep 28, 2010 | 07:51 PM
Nopike's Avatar
Heated seats fuse is F29 (10Amp) in the underdash fuse box. That is the only this that fuse is used for.
Old Aug 1, 2011 | 03:16 PM
BGoetz's Avatar
Heated seat wont shut off
I own a 2004 Max SE with heated seats and they randomly turn on even with the switch off. I tried looking for the harness to disconnect temp thru the summer but cant find it. No fuse is set for just the heated seats, it disconnects the entire seat.
Any suggestions before the shop?
Old Aug 1, 2011 | 04:13 PM
tigersharkdude's Avatar
wrong section, you should post in the 6th gen section not the 4th gen.
What do you mean by "Any suggestions before the shop?"
Old Aug 2, 2011 | 10:07 AM
He means....any ideas before he takes his car to a a dealer/mechanic.
tarun900
19
Dec 20, 2021 06:57 PM
Fbana41
Aug 29, 2016 12:18 PM
sliptap
Sep 30, 2015 05:57 AM
uttadms31
Sep 30, 2015 05:24 AM
Max Nu-BE
Sep 28, 2015 10:25 AM
