Racing Steering Wheel Installation?
Old Dec 29, 2004 | 05:34 AM
JetBlackMax's Avatar
Hello all. I just bought a SPW Steering wheel for the Max with a Hub Adaptor. Does anyone know where I can find a right up of how to install this? My brother said it might be complicated because of the Air bag but I have seen this done on a Max before. Anyone know how to install? Or where I can get the write up? Thanks
Nick
Old Dec 29, 2004 | 09:12 PM
Anyone at all?
Old Dec 30, 2004 | 07:56 PM
Hey man. Thank you so much, I really appreciate your help. Ill let you know how everything goes when I install the new wheel. Thanks again!
Nick
Old Dec 30, 2004 | 08:03 PM
jdm71488's Avatar
pic request post/during install if possible, please... thanks
Old Feb 19, 2005 | 04:21 PM
blackmxma's Avatar
hey man, I'm tryin to install a sparco wheel with momo hub adaptor but I'm having trouble with the turn signal cancelor. do you have any instructions or a write up? thanks
Old Feb 21, 2005 | 05:07 AM
euromaxima's Avatar
use the special tool to remove the air bag, then i think its a 19mm socket to remove the steering wheel, then I think you just put the hub kit on and screw the 19mm bolt back on and put your new wheel on. you will loose cruise control.
Old Feb 22, 2005 | 07:23 PM
blackmxma's Avatar
hey euromaxima, were you able to get the horn and turn signal cancelor to work?
Old Feb 23, 2005 | 04:49 AM
euromaxima's Avatar
nope, If I wanted to I could probably get the horn to work but the other I don't know how to make it work.
Old Feb 23, 2005 | 12:51 PM
Ceasars Chariot's Avatar
Old Maxima Legend
someone do a right up with photos once its done
Old Feb 23, 2005 | 01:58 PM
DR-Max's Avatar
Switching to aftermarket steering wheel is more hassle than its worth but if you don't mind it, then by all means go 4 it! Plus you loose all the necessary stuff like horn control, c/c, and more importantly airbag. Even if you get the horn control to work, it gets flakey. Nothing is more reliable than a OEM wheel.The only thing I see worth switching to is perhaps a newer 4th gen wheel. I'm not sure how it works with other gens.
trasmadean
Feb 1, 2017 08:20 PM
Maxima_Joe
Nov 25, 2015 08:19 AM
Maxima_Joe
Oct 15, 2015 08:01 PM
Flores94
Aug 13, 2015 01:17 PM
MikesChevelle
Aug 6, 2015 11:36 AM
