Car dies on idle (random times)
Old Jan 1, 2005 | 11:02 AM
multiplexor's Avatar
Hey guys,
Last night when i was driving to a new years party, my car stalled at a stop. I was like... uhm ok.... so i start it, and notice it's having a rough idle... so i take off... get to my destination and the car just stalls again. I start it, it stalls, start, stall... i start it, floor it and it stays on when i'm pressing the gas. When not, it stalls again. I like giving things time, so i goto my party, later that night come out to start it and leave (sober ) and it starts fine.
I drop some friends off about 5miles down and when i stop there, it stalls.
I start it up, it's ok again, I get home and it's got a semi decent idle...
any ideas whats going on? I know my coil packs are not all measuring the same resistance...
Could it be the fuel pump? coil packs?
note, i was also getting hesitation when on the road... the car sometimes felt like it was losing power and then it would come back. Like a knock sensor sudennly going bad, then coming back again...
Any ideas guys?
Car: 96 maxima, manual trans, 122,000 miles
Old Jan 1, 2005 | 12:13 PM
MDeezy's Avatar
if you know your some of your coils arent mesauring the right resistance then you know those will need to be replaced.
Check vacuum lines make sure there are no holes or leaks (but if you had one I'd like to think that you'd stall all the time, not stall then fine then stall then fine.)
check Maf.
Hmmm . . thinking what else. . .
Old Jan 1, 2005 | 01:46 PM
njmaxseltd's Avatar
Sounds like a dying MAF sensor.
Old Jan 1, 2005 | 01:48 PM
kcryan's Avatar
vacum lines or a tb in need of cleaning really bad? mabye coils
Old Jan 1, 2005 | 02:21 PM
2 Da Max's Avatar
bad coils on a 96 hmm doubt it, sounds like maf goes into protect kinda. does it go past a certain rpm?
Old Jan 1, 2005 | 07:18 PM
cefiro a32's Avatar
I had a similar problem recently. I checked the ecu which gave me code 0304(knock sensor). I replaced the sensor and the car drives like a dream. Check your ecu
Old Jan 1, 2005 | 09:10 PM
2 Da Max's Avatar
ks wount cause the car to die. just retards thet timing
Old Jan 1, 2005 | 10:46 PM
nismology's Avatar
FUEL FILTER!!! That would be the first thing i replaced.
Lakersallday24
Jun 16, 2019 01:35 AM
maxinout93
Oct 27, 2015 01:29 PM
Balkins
Aug 12, 2015 06:39 AM
Maxboy23
Aug 11, 2015 11:59 AM
