Injen Intake....
Old Jan 3, 2005 | 02:03 PM
JaMdMax97's Avatar
Injen Intake....
I have heard Pro's and Con's to the Injen intake..I just want a simple answer is it a good intake, and will it make improvments in performance...?
Old Jan 3, 2005 | 02:10 PM
2k2kev's Avatar
It's chrome alright...
If you want answers to those questions then you haven't heard the pros and cons......... TRY READING THE FORUM FIRST!
good? sure
performance? no intake is going to make noticeable performance gains
read my sig? scroll back 2 or 3 pages to read the other 12 injen/intake threads
Old Jan 3, 2005 | 02:18 PM
JaMdMax97's Avatar
ight thanks
Old Jan 3, 2005 | 08:40 PM
gsmith795's Avatar
good? sure
on my old 3rd gen i easily noticed some increase in power and more aggressive sound when i did a simple K&N drop in. notice how i said "some increase," but it was still there. my stillen intake on my 4th gen sounds awesome and although i couldnt compare it to stock (was already installed when i bought it) im guessing there was some increase in performance. i would say dont buy the injen unless you have lots of cash to spare cause you are mostly paying to have the word "injen" written on the side of it...
Old Jan 3, 2005 | 08:44 PM
n2o_matt's Avatar
my hai droped me .4 in the 1/4 :shrug:
Old Jan 3, 2005 | 08:58 PM
2k2kev's Avatar
The best I've seen written around here for any intake on a maxima is about 7 or 8hp (which I don't believe, but whatever)....... you're saying an 8hp increase accounted for a 0.4s decrease in 1/4m time?
Did you ever think there might have been something else involved?
Old Jan 3, 2005 | 08:59 PM
optimus310's Avatar
best looking intake under the hood, and sounds awesome
Old Jan 3, 2005 | 10:01 PM
maxima619's Avatar
Former Sponsor
Get Place Racing cold air intake, they are cheaper, nice sound, Injen is not a true cold air intake. An other good option is the Jim Wolf pop charger, dont get injen, it is way too expensive, place racing and jim wolf are under 150 bucks.
Old Jan 4, 2005 | 04:27 AM
chenzarino's Avatar
get e-bay injen knock off for 50 bucks shipped.
Old Jan 4, 2005 | 05:41 AM
MrEous's Avatar
^ Jeff™
Injen = ~140degree temps...great location behind the radiator. Even with a heatshield you will get the higher temps. You also run the highest chance of injesting water into your engine with the Injen.
Even a cone filter behind the battery gets better temps.
Old Jan 4, 2005 | 06:27 AM
2k2kev's Avatar
Explain to me how the temps are lower further up in the engine bay where there is less air circulation and more heat is trapped.
Explain to me how, if injen is taking in 140* air, I can go for a hard drive and get out and put my hand directly on the tube and not have it feel hot.
Explain to me how air is taking a 180* turn to get in the injen filter, because it's NOT BEHIND THE RADIATOR FAN .... so somehow, while I'm moving forward, you're saying air is coming in through the radiator, being redirected AWAY FROM WHERE MY INJEN FILTER SITS by the black plastic shroud behind the radiator......
Go away.
oh yeah, you have to drive through at least 14" of water to submerge the end of the tube, so anyone driving through that much water *should* get a blown engine.
Old Jan 4, 2005 | 06:29 AM
JaMdMax97's Avatar
keep it comming boys
Old Jan 4, 2005 | 07:51 AM
optimus310's Avatar
Go away.
Don't even waste you time trying to defend the Injen. This is Maxima.org, and the hack air box is the best intake ever.
Lets just say that every person I've herd that has an injen loves it including me.
Old Jan 4, 2005 | 08:23 AM
2k2kev's Avatar
I have one, too, and I'm realistic about it... I know it didn't decrease my 1/4m by a second, I know it didn't make my "mid-range throttle response 10x faster" (whatever that means, and however anyone would even measure that ) and I know place racing, berk, franken, and the e-bay knockoffs don't do those things either.
I also know injen costs more than those, that's why I bought mine used
edit: oh yeah, and about the hacked airbox... would you buy a used car that someone cut holes in? I know I wouldn't. The hole in the airbox wouldn't bother me but the fact that someone was willing to take a saw to the airbox would be a huge red flag in my head that this person probably did something else that I wouldn't want to own later on.
Old Jan 4, 2005 | 08:40 AM
MrEous's Avatar
^ Jeff™
Go away.
Read this bit of info and admit you were wrong...
http://forums.maxima.org/showthread....ighlight=injen
Sorry I said 140...I meant 130 which is still damn hot at idle when a CAI is supposed to be helping the engine. At idle the cone filter is the same temp but when cruising/WOT the temp of the WAI is actually 20-30 degrees cooler.
Old Jan 4, 2005 | 08:51 AM
MrEous's Avatar
^ Jeff™
I also said you run the HIGHEST CHANCE of injesting water compared to ANY OTHER intake system out there. Injen is ~14"...PR CAI is what, 28"?
Old Jan 4, 2005 | 08:53 AM
2k2kev's Avatar
Nifty, neato, yippee...temps differ in differen't parts of the engine bay.
How about you read this threa then admit you are wrong about the benefits of *any* intake.
http://forums.s2ki.com/forums/index....owtopic=204172 (most interesting reading is on page 2)
<cliff's>
Pipe length affects the resonance of the pipe, a longer pipe having a lower resonant frequency. Hence longer pipes resonate, and produce additional torque, and lower engine speeds. In theory, a shorter pipe produces more horsepower, because it produces an increase in torque at a higher RPM. In practice, peak power is obtained when the intake is tuned to the speed at which peak HP is produced. That and the thread above say the length of the tube really doesn't matter as much as how well that length was tested and tuned to the engine. A short tube might be complete crap and a long tube might make your engine crank, but change the length of either tube a few inches and you change the resonance and ruin everything.
Then read this thread and admit "ram air" is a myth and doesn't do anything besides sell intakes and cars labeled "ram air".
http://www.vetteguru.com/ramair/
Old Jan 4, 2005 | 09:51 AM
MrEous's Avatar
^ Jeff™
You wanted to argue the fact that you thought the Injen was far superior in pulling in COLD AIR. Now you are changing the argument to pipe lengths and optimal hp.
Can you make up your mind?
It doesn't matter WHICH intake anyone gets if they are looking into getting better 1/4mile times...since all intakes are within ~.5 tenths of each other and ~.5mph as well.
If they are a highway driver then a cai is not necessarily the best way to go since the length of the pipe takes away power from the highend.
Midrange to low-range would be CAI like PR or Injen.
...and I never said a thing about 'Ram Air'.
Old Jan 4, 2005 | 10:16 AM
2k2kev's Avatar
You wanted to argue the fact...
I wanted to argue the fact that no intake gives any significant gains. You appear to be saying place racing's "true cai" is "better" but the only criteria you're using is cold air. I'm saying cold/cool/warm air doesn't matter nearly as much as having an intake that's tuned to the specific hp range of your car....... so I'm getting back to my original argument in post #2:
also, ram air was all over that other thread so I assumed because you believed everything else in that thread you also believed ram air was real.
Old Jan 4, 2005 | 10:20 AM
ALC252DM's Avatar
Uh-oh......now the intake-god is on you like bug spray on bugs!
*edit*
I think Cliff's comment basically means that the design intended by the manufacturer (Nissan engineers) is probably the best design for the engine. It's just a matter of filter element that would yield some type of improvement. Being that Nissan even put a snorkel to direct cooler air from the outside indicates that they know how cold air increases performance. So changing your intake, no matter what type it is, is just can potentially "ruin everthing" that the engineers have so carefully designed and tuned. The sound somehow feels people into thinking they are going faster. Why do you think there's a lot of Civic's with noisey exhausts? Just my 2 cent.
Old Jan 4, 2005 | 10:38 AM
MrEous's Avatar
^ Jeff™
No...I'm just anti-Injen due to the design and how its sold as a cold air intake when data suggests otherwise. People pay upwards of $200 for something that gives just as much gains as a cone filter. A cone filter + adapter would run about 10% the cost of an Injen.
That's all I was saying. You're exactly right...no intake besides f/i would give any significant gains. 5hp only adds up to maybe a 5-hundredths of a better time in the 1/4. It's almost laughable how many will flock to the pricey intakes just because they either look nice or how the great '5-8hp increase' marketing scheme works.
Old Jan 4, 2005 | 11:33 AM
ALC252DM's Avatar
What's more laughable is that people get into heated arguments about it, over 5-8hp (if that) increase. No pun intended to you of course. I have a pop-charger intake myself. And before I was going for the PR w/o the midpipe, but I've read about the pro's and con's about it and I am not willing to shell out more money for the trade-off (loss of high end for increase on low end). So I'm just going back to stock setup to get some low-end power back. However, I'm gonna cut a 3" hole under the lower half of the box and into the wheel hump. Then run a short plastic pipe thru them. This pipe will divert the same cool air found by the PR setup (within the space inside the driver side fender well cover) w/o the risks of getting water into the intake. Then I can use a K&N panel filter and be done with it. Of course, this is an idea in the initial phase. I have to look inside the fender well cover and see that flow of air isn't restricted in any way.
Dasmith
Aug 25, 2015 10:15 PM
PCGuRu2K
Jul 19, 2002 09:47 PM
MichaelAE
Jul 6, 2002 07:43 AM
