Raised idle with AC/Heater on.
Hella internets
I know the idle raises within 100-200 RPMS with the heater or AC on. But the other day i noticed with my heater on (manual setting number 1) that when i parked my idle was almost @ 1k RPMs! Is that normal? If not what could be causing this issue?
Originally Posted by Batxel
same here... mine goes up to about 900 with AC or defrost on. My previous car did this as well.
Yup yup - the AC and front defroster kick mine up to almost 1k, but pushing warm air on the other vent controls does not.
I don't think its normal with just the heater, at least my idle doesn't change (I have a 5speed). I believe the idle speed is increased to get the belt driven compressor to its job. To my knowelege the compressor should not be on when you are just using your heater so your idle shouldn't change. I would assume you have either bad relay or switch. You should look under the hood and see if the compressor is on when just your heater is on.
NOTE: I am not an A/C, deforst, heater expert which means everything I just said were just assumptions...
