auto transmission problem
Old Jan 10, 2005 | 06:40 PM
mymax1995's Avatar
I had a leak in radiator just changed it with a new one.I replace ever hose to the right spot started the car (1995 maxima) temp o.k drives forward but does not want to go in reverse gear and if it catch the transmission starts to shake.Help
Old Jan 10, 2005 | 07:15 PM
Bags's Avatar
VG Ridah's Biatch Hoe
My only guess is that the radiator fluid leaked into the tranny... VERY BAD NEWS if this actually happened.
Try draining the fluid ASAP and put in new fluid and see if that helps.
Were there any problems before?
Old Jan 10, 2005 | 08:08 PM
SXN's Avatar
SXN
only way it could have been caused by the tranny swap is like bags said, fluid getting into the transmission. it could get on various parts, that would cause slipping...but that sort of binding and shaking sound odd. any noises or grinding? also, if you had a shop do the install (doesnt sound like it from the brief description) make them deal with it...they broke your transmission!
Old Jan 30, 2005 | 02:29 PM
mymax1995's Avatar
Thanks for the info.but this car has no been in a shop for 3 years I do want I can on it, the day it was driven home I saw antifreeze leaking form the top of the radiator bought a new radiator relpaced it same day never had a tranny problem one hour job in garage try back out and no reverse.changed the fluid and nothing.runs through all the forward gears fine.
sctludwig
Sep 1, 2022 01:32 PM
boomerbrian
Oct 31, 2018 10:25 AM
I<3 A32's
Sep 10, 2015 11:07 AM
slowlifer
Sep 8, 2015 05:53 AM
