Has anyone done this before with their intake?
Old Jan 12, 2005 | 11:19 AM
  #41
stephenlc's Avatar
I have another filter that is a little bit bigger, I am going o see if I can get it to fit. These damn headers are a ***** to install, I have the front ones installed now the back ones to do. Lunch break first though.
Old Jan 12, 2005 | 11:36 AM
  #42
ALC252DM's Avatar
Must be nice to have some time to work on your car. I've been wanting to work on my car and the last 2 weekends have been raining out here. I gotta do the pillar mod and fix one fog lamp. And hopefully if I get my GR2's, I'll put that in too.
Old Jan 12, 2005 | 03:13 PM
  #43
sterlingmaxima's Avatar
ahhhhhhhhhh i love the sound of headers i dont even care about the power and teh look so sweet lucky bastard!!!
Old Jan 12, 2005 | 03:24 PM
  #44
Maxima99SE's Avatar
will fly for food
that filter setup with a hacked airbox might be cool...
Old Jan 12, 2005 | 03:39 PM
  #45
XeroX's Avatar
Hella internets
Originally Posted by ALC252DM
I think you'd get a more accurate comparison between stock vs. non-stock by putting the resonator box back in since that is part of the stock system. Then take it out and put your aftermarket setup and dyno again. If you are comparing filter elements, panel vs. cone, inside the air box then you should leave the resonator box in for both tests that way your comparison is more accurate. There's a dyno in here comparing stock vs. frankencar hybrid intake (with midpipe, I think) and there's a noticeable loss (in dyno) in HP/TQ with the hybrid setup. Butt dyno, not sure if you can feel the difference, I probably won't. Having the midpipe will only give you more noise at WOT. Not sure if you've seen that, its in a thread somewhere in the 4th gen forum.
Doesnt really loose power, mostly just moves it somewhere else on the graph. ALthough i HAVE seen these dynos, i have to argue a bit.
Spanish:
Did i get you thinking on how you can improve your setup with my mid-pipe ideas? lol...
Old Jan 12, 2005 | 03:59 PM
  #46
stephenlc's Avatar
whats your midpipe idea? No pictures today, sorry. I have everything back together but I wanted to take some pictures. Haha I didn't put the rear header on, I hve the stock one on. I was getting so tired and frustrated with the firts one I didn't want to do the rear. The rear one look easy except I probally have to cut off the heat shield and one of the nuts is right in front of the rear motor mount!!! Thats going to be a ***** to get off so I don't want to mess with it. Pictures will come tomorrow and hopefully when I start it it doesn't act goofy.
Old Jan 12, 2005 | 09:25 PM
  #47
DAVE Sz's Avatar
Hooooooonda.....
I am going to use everything from the stock intake includin the air dam thing that is connected to the radiator support, so the cold air will b coming from there.
Knowing you I should've figured that out. You're not gonna use a midpipe are you? Then again I noticed that on a 5spd there is no difference between a midpipe and the stock square resonator.
Old Jan 13, 2005 | 06:25 AM
  #48
stephenlc's Avatar
no midpipe, everything stock.
Old Jan 13, 2005 | 03:49 PM
  #49
welli am gonna try out your idea tonight so I ill see if it is good if so I will post pics and my opinion.
Old Jan 13, 2005 | 08:31 PM
  #50
stephenlc's Avatar
sweet, show me pictures, haha. Ill give you some tips with the dremel if you need help. I'll post pictures on monday, I have my midpipe on now. I couldn't find all the hardware for the stock intake but I found it now, but for some reason I think I have a 5th gen bendable rubber thing that connects to the throttlebody because its way bigger, it must of come from my VI box.
Old Jan 13, 2005 | 08:38 PM
  #51
maxspeed96CT's Avatar
The original VQ...
wow that looks cool, you the get the benifits of a pop charger but the air might be alitle bit cooler.
you are leaving the bottom open right?
Old Jan 13, 2005 | 08:58 PM
  #52
stephenlc's Avatar
no I am putting it in the stock airbox, nobody will see that its a cone filter in there.
Old Jan 13, 2005 | 09:31 PM
  #53
okay dude I tried it it woudlnt work. now I trully understand how small that filter is I figured mine might pull the task off but it was like the double the size neede which is sad. Any suggestions on a smaller filter I could use?
Old Jan 13, 2005 | 09:49 PM
  #54
stephenlc's Avatar
not sure, I got that one with my CAI, I could take measurements, but I'll post them late rI am tired
Old Jan 13, 2005 | 10:57 PM
  #55
lol me too dude, cabniet making for four days. no more cabinets!!!!!!!!!!!!!!!
Old Jan 14, 2005 | 07:17 AM
  #56
Ninos_Maxima's Avatar
be the change u want2C
sounds restricting to me, gotta see the pics, hurry up and post them, hehee
Old Jan 14, 2005 | 08:03 AM
  #57
maximabebe's Avatar
Hmmm, slap a small mid pipe in betweeb the air box and the throttle body. I'll bet you its loud as hell.
Old Jan 14, 2005 | 10:42 AM
  #58
Phatbashar's Avatar
The stock location will always be better. Nissan engineers designed it this way. Cold air comes in through the scoup and straight to the filter, instead of sucking up the high engine area temps. Only problem with the stock intake system is they didnt want to make it LOUD as hell. Looking to satisfy all markets. So they gave a thinner intake plumming and a restrictive filter.
The best soltion would be to upgrade the plumming going to the airbox, and do the filter in the box teh same exact way he did. This will suck up all the colder air AND increase the total volume/velocity of air coming in. Or, you can simply throw in a drop in K&N into the stock airfilter housing and upgrade the plumming thereafter as well. Either way, this is the BEST WAY to increase total power output.
My 2 cents.....
Old Jan 14, 2005 | 02:27 PM
  #59
Dooley's Avatar
Blast through the hood and put a circa-70's Mopar hood scoop on.
aw11power
Oct 10, 2021 04:57 AM
JonBlz
Oct 5, 2015 06:02 PM
maxima297
Sep 30, 2015 03:32 PM
09maxshawn11
Sep 30, 2015 10:28 AM
MichMaxFan
Sep 30, 2015 09:18 AM
