a/c problems.... compressor maybe?
Old Jan 13, 2005 | 04:16 PM
hott_nikkelzz's Avatar
the air coming out of my a/c is not as cold as it used to be..... refilled it.... and no change.... so im guessing it is the compressor...... or maybe even the condensor? Any suggestoins would be appreciated..... thx
Old Jan 13, 2005 | 04:51 PM
NEW2DAGAME's Avatar
How long did you let it run? If you dont use it much, it takes a while for the cold air to kick in.
Old Jan 13, 2005 | 05:21 PM
well.... its been like this since last summer.... i just wanted to do something about it now b4 this summer.
Old Jan 13, 2005 | 06:54 PM
chuckie311's Avatar
go get it checked i had a test ran on mine and found out it was the expansion valve
Old Jan 13, 2005 | 10:58 PM
bct1192's Avatar
My compressor went bad a couple weeks ago. I was able to tell by looking at the clutch/pulley assembly on the outside of the compressor. This is a bit hard to describe in a way that makes sense if you have never seen it, but I will try. The clutch/pulley assembly is a circular piece with a pulley on the outside that can spin free of the clutch on the inside. When the ac is not engaged, the pulley spins freely and the clutch assembly does not move. When the ac is engaged the clutch locks and spins with the pulley, activating the compressor. To check if it is working, start the engine with the ac off. The pulley should spin, but the clutch should not be engaged, so it should not move. Then turn the ac on. Check the clutch assembly now to see if it is spinning with the pulley. If it is not, then your compressor/clutch assembly is to blame. You could replace just the clutch, but this is much more difficult, and the clutch costs almost as much as the whole compressor.
Old Jan 13, 2005 | 11:40 PM
goodhead's Avatar
hey u can buy my compressor for $50+ shipping!!! jsut took it off today works perfect, i also have the bracket, condensor and the catch
BkGreen97
Apr 2, 2016 05:47 AM
mclasser
Sep 24, 2015 11:57 PM
homewrecker
Sep 24, 2015 07:01 PM
pears
Sep 18, 2015 05:25 AM
