painting calipers????
Old Jan 17, 2005 | 12:49 PM
guyfromkop's Avatar
how much of a pain in the a$$ is this?
Old Jan 17, 2005 | 12:58 PM
BlackCat's Avatar
RIP '98 Maxima SE
Its easy to do. Just make sure you spend the time to cover areas you don't want oversprayed.
Old Jan 17, 2005 | 01:06 PM
guyfromkop's Avatar
do i have to sand anything down?
Old Jan 17, 2005 | 01:07 PM
Tek-Niq's Avatar
my rear view mirrors flap like a f-ing bird
yea, just be carefull you don't spray anything else....
Old Jan 17, 2005 | 01:09 PM
Tek-Niq's Avatar
you might wanna clean the caliper before you spray it. you wanna take brake dust off and stuff like that...
Old Jan 17, 2005 | 01:53 PM
Irish's Avatar
This is a democracy
go to wal mart, they have a kit that i used to paint mine red... its by dupont, it was like 15-17 bucks if i remember right.....heres how that turned out
Old Jan 17, 2005 | 01:55 PM
95bkackmax18s's Avatar
when i did mine ( silver) i bought a kit that you paint on with a brush, i did about three coats and it seems to be doing fine, no chips. it was about $20
Old Jan 17, 2005 | 02:27 PM
finny's Avatar
its however much of a pain you want it to be. personally i do mine every spring, just degrease them, wire brush them and just use a peice of cardboard to try and not spray everything else, and take about an hour or so. although if you take the time prep everything right and are very particular on the results and want it to last you can spend a whole weekend on them. id say how much of a pain it is will be determined by the job you want done.
Old Jan 17, 2005 | 03:07 PM
Cutler's Avatar
Use a brush on kit, better quality and not ghetto.....
Old Jan 17, 2005 | 03:15 PM
BlackCat's Avatar
RIP '98 Maxima SE
The only pain was the time required in jacking up the car, taking off the wheels on one side and prepping each caliper.
Old Jan 17, 2005 | 03:25 PM
ronin22357's Avatar
i used a brush on kind but it only lasted about a year. Now they are powdercoated and no problems. the paints will fade eventually
Old Jan 17, 2005 | 03:44 PM
bullfrog's Avatar
who was it that polished his calipers? that looked hella good. if i do anything to mine, that's what it would be, even though it would take lots of time and effort.
Old Jan 17, 2005 | 03:46 PM
2 Da Max's Avatar
i think it was y2ksteve? noo jeff92se i belive? they were the 300zx calipers
Old Jan 17, 2005 | 04:33 PM
JaMdMax97's Avatar
you want to polish them and your wondering about how much of a pain in the *** the painting process is...just times the painting process by about 100000X and you will get how much a paint in the *** it would be to polish those things...just paint them they look nice when they are painted!
Old Jan 17, 2005 | 06:03 PM
99maxk2's Avatar
Just take the caliper off to make the job 10 times easier...
Old Jan 17, 2005 | 06:06 PM
rsly33's Avatar
Or just buy a G2 kit or Foliatec kit and paint it on. Thats 100 times easier than taking off the calipers
Old Jan 17, 2005 | 06:20 PM
99maxk2's Avatar
calipers are really easy to take off
Old Jan 17, 2005 | 10:30 PM
tbombs32's Avatar
i just did mine its really easy takes a little bit of time depends on how dirty ur calipers are. youll need to sand them a little but its not a big deal. i used the paint with a brush so i didnt have to take anything apart. i heard the spray is more durable and lasts longer not sure if thats true tho. i jacked up one whole side and did 2 calipers. took about an hour to hour and a half. then did the other 2 the next day.i say do it. looks real good after.
Old Jan 18, 2005 | 07:46 AM
acj's Avatar
acj
Seems like everyone has this locked down...but why not one more post. I painted mine when I was changing my pads because everything was already apart. I just used an AlumniBlast engine spraypaint and it worked fine. Its been on there about a year now and still looks good. So spending $20 for a kit just doesn't seem right...
Old Jan 18, 2005 | 09:42 AM
rsly33's Avatar
The G2 and foliatec kits are very good. Everyone in this thread that said they had problems with fading used spray or the duplicolor kit. Not saying the g2 and foliatec wont eventually fade, because everything will end up fading, but it takes a lot longer than others.
Old Jan 23, 2005 | 01:51 PM
Stuntin' 101's Avatar
when i paint mine, all i do is clean everything off with brake cleaner.. mabye ill wire brush the caliper quick.. then i just spray everything.. EVERYTHING.. the complete rotor too.. i do mine black, cause i just want them to look clean, not draw attention like a highlighter.. but anyway, the benefit of doing it this way is for one, its much easier, and number too, everthing that the brake pad does not touch, stays the color you paint it.. Especially the rusty ring on the rotor where the pads dont touch.. all stay look nice and clean.. the pads wear the paint off the rotors really fast, even just goin around the block a few times.. if you ask me, all this taping up and covering is alot of overkill, and doing it my way looks better imo.
Old Jan 24, 2005 | 10:20 AM
Jeff92se's Avatar
I'm needing a caw
Someone ring?
Old Jan 24, 2005 | 11:49 AM
bullfrog's Avatar
Originally Posted by jeff92se
Someone ring?
yeah! That's what I was talking about. Those things are sexy!
Old Jan 26, 2005 | 10:36 AM
wmhashem's Avatar
Very Sexy Baby< Im Hard
Old Jan 26, 2005 | 11:37 AM
MAXRB8's Avatar
Brush on lasts just as long as spray, and no masking required as long as you have a fairly steady hand
Old Jan 26, 2005 | 02:39 PM
sterlingmaxima's Avatar
I second the duplicolor the only reason it would fade is if you did it wrong mine are still shinning. the folitech stuff blows more expensive and it sucks
Old Jan 26, 2005 | 02:42 PM
Maxima99SE's Avatar
will fly for food
I used a dupont kit from wally world, painted on with a brush about 6 months ago and when clean, they still have a good amout of gloss
Old Jan 26, 2005 | 02:56 PM
MAXRB8's Avatar
Here's a pic from Jan 2004:
and here's a pic from Jan 2005:
I have noticed any color fade, I haven't done any touch ups just wash mit though the spokes, I used Tremclad brush and it wasn't even high heat as I had it left over in the garage from painting my midpipe.
Old Jan 27, 2005 | 04:31 AM
Big Tyme's Avatar
If you want to spend about $6 bucks to do this, go to wal-mart, autozone, wherever and pick out your paint (High Temp of course). Then go to wal-mart and get some foam applicator brushes. The wal-mart here has them in the craft section. The brushes are wedge shaped with a wooden handle, they're like 35 cents apiece. Now spray the brush with your paint and become Picasso. The paint goes on nice and you don't have any bristles to slide all over everything or fall off.
REDinLV
Aug 15, 2024 12:30 AM
litch
123
Jan 4, 2024 07:01 PM
Apr 16, 2020 05:15 AM
imported_Nismo_max
Sep 21, 2015 07:24 PM
beerman1378
Sep 8, 2015 02:19 PM
