ECU Question.
Old Jan 18, 2005 | 12:56 PM
maximazation's Avatar
ECU Question.
I recently got the Technosquare ECU w/o a raised limiter. I just wanted to know how long it would take for the ECU to fully work or can you feel the difference right away? I was also wondering if the new upgraded ECU will change my gas mileage? And also what performance should I expect from the ECU?
Old Jan 18, 2005 | 12:57 PM
mzmtg's Avatar
Minister of Silly Walks
Shouldn't you have asked TechnoSquare these questions?
Old Jan 18, 2005 | 02:26 PM
Just thought I try here first
Old Jan 18, 2005 | 02:30 PM
NmexMAX's Avatar
dot dot dot ...
1.) Baseline dyno, compared to new ECU Dyno.
2.) Record what MPG you were getting with the old one, and compare it with the new one with similar driving conditions etc.
Old Jan 18, 2005 | 03:03 PM
nismology's Avatar
Just FYI, you won't feel the power increase until basically WOT. Around town driving is unaffected.
Old Jan 18, 2005 | 03:07 PM
NmexMAX's Avatar
dot dot dot ...
Funny, I saw gains that helped around town driving more than anywhere else, though given I do have the JWT.
Old Jan 18, 2005 | 03:09 PM
nismology's Avatar
The JWT doesn't take over until open-loop mode either. You must drive your car pretty hard around town.
Old Jan 18, 2005 | 03:11 PM
NmexMAX's Avatar
dot dot dot ...
What I meant was mid range RPM's
Old Jan 18, 2005 | 03:16 PM
nismology's Avatar
I see. However going into open-loop mode has to do with throttle position more than RPM.
Old Jan 18, 2005 | 06:32 PM
eng92's Avatar
The TS modified fuel and timing maps only come into play at WOT above 3K.
There will be no change in fuel mileage.
Personally, I felt minimal difference (butt dyno) between stock and the first TS ecu I had. Back to back dynos (stock vs TS) is the only way to verify the gains, if any.
Old Jan 18, 2005 | 10:03 PM
jcy98maxse's Avatar
Turbo is too much fun!
He bought the ecu from me. BTW got your email too.
No change in mpg unless you wot all around town cuz it didn't effect closed loop, only open. To me it just reved smoother and a little quicker, I do have other mods too ie flywheel and pulley. so that would affect the way the car ran. Also I have a JWT now and it doesn't affect my mpg either.
Old Jan 19, 2005 | 12:41 AM
thanks for the tip peoples. my next mod im planning for now is the MEVI and when that happens, im gonna send the ECU to Technosquare to get the extended rev limiter.
Old Feb 10, 2005 | 09:24 PM
michaelnyden's Avatar
they still haven't figured out the extended rev limiter...they say they have...but not one person so far besides cheston has successfully had their rev limit raised...and that is with a good amount of time looking at a JWT chip to compare code so they could figure it out...but still couldn't for some reason...
Old Feb 11, 2005 | 11:07 AM
laylow1988's Avatar
i just called technosquare at 11:30am and this guy told me $595 for the ecu and they only do the fuel and ignition. not the rev limitor i repeat not the rev limitor so i dont know what you guys are talking about they do it. dont beleive me call them 310-787-0847
Old Feb 11, 2005 | 01:00 PM
ask for Brian....when you call them...and oh, if you talk to him...ask him to finish re-modding my ecu and send it back to me (Michael Nyden '95 maxima) cause it's been over 2 weeks now...this is ridiculous!!!
Old Feb 11, 2005 | 01:14 PM
WielkiWaac's Avatar
MaximaDriver
Dont you think they'll say that there is no changes in gas milage. And power gain up to 15 HP??
Just think abou it!!
Old Feb 14, 2005 | 05:10 AM
laylow1988's Avatar
by the way jwt has a sale going on until the end of feb for $500
Old Feb 14, 2005 | 08:09 AM
Terran's Avatar
But you won't get it back until June
Just make sure you have an extra ECU so your car isn't useless until they finally send it back.
Old Feb 14, 2005 | 08:14 AM
DAVE Sz's Avatar
Hooooooonda.....
You're trying to make sense, but you're not. If anything they'd say gas mileage would be better.
Old Feb 14, 2005 | 08:48 AM
I30tMikeD's Avatar
The daughter board that is added to the stock ECU only comes into play in open loop mode, which is somewhere around 50% thottle. Don't know for sure but it is not just WOT.
The gains are right away. None of this ECU learning stuff you migh have read.
Gas mileage will be dependant on your driving habits, not the ECU. Actually, it could be better in theory since the A/F ratio is leaned out.
10-15 lbs of torque through most of the power band from 3K and up. A solid .3 gain or so in the 1/4 mile
Old Feb 14, 2005 | 12:19 PM
Dman832's Avatar
Are you sure about the $500 quote for the ecu? I looked on their website and saw no mention of it. If it is on sale this month, I will absoluetly buy one, I have been waiting for some kind of a deal for a while, and since I just got a MEVI, this is a crucial upgrade.
Where did you see this sale??
Old Feb 15, 2005 | 07:32 AM
laylow1988's Avatar
call them up ask for andy 480-216-5855 (they beleive everyone else except me )
Old Feb 15, 2005 | 10:19 AM
Dman832's Avatar
cool, thanks, I will call him today
Old Feb 15, 2005 | 10:23 AM
deezo's Avatar
If any?????? There are gains with the TS ECU.
Old Feb 15, 2005 | 11:07 AM
eng92's Avatar
I agree
But the gains were certainly nowhere near as substantial with the first ecu I got from TS. On that one, I measured the timing advance at barely 2 degrees above stock and could not "feel" any gains. Plus, no extended rev limiter.
Old Feb 15, 2005 | 11:30 AM
bignutts
so if you ask for extened rev and you dont get it i guess you can send it back and get a new one? which will make me doubt the companyand call it
Old Feb 15, 2005 | 11:50 AM
oTranscendental's Avatar
Wow, for $595 I was expecting to see gains of at least 20 HP plus the rev limiter not being raised, and the advanced timing only at 2 above stock. This seems like a horrible waste of money. Might as well spend it on someting else.
I was really looking to get one but this thread makes me think twice. I saw the dyno, but with the inconscitancy between ecus from the SAME company..... thats just sketchy.
gigabyte
Jan 6, 2017 06:05 PM
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
doctorpullit
Mar 29, 2016 11:08 AM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
pears
Sep 18, 2015 05:25 AM
