Auto Antenna
Old 01-22-2005, 10:38 PM
MattsMaxx04's Avatar
Auto Antenna
My antenna doesn't work since I hooked up my new head-unit amp and sub. Does anyone know if it's just hooked up wrong or is it somthing with power antennas or what? My amp and sub didn't work so I re-did everything now they work but my antenna doesn't ?????
MattsMaxx04 is offline
Old 01-22-2005, 11:02 PM
ewuzh's Avatar
With most aftermarket units, the antenna should only go up when the radio is on. It won't go up when using the CD player. I don't know whether this is the case with you.
ewuzh is offline
Old 01-23-2005, 04:50 AM
nitromax's Avatar
depending on the hu brand, you may only have one remote turn on wire (blue or blue w/white stripe). if that's the case,then you'll have to tap into that wire to power the antenna & amp. if you tap into that wire you could also add a switch (on/off), so the ant is only up when the radio is on and down when the cd player is on.
nitromax is offline
Old 01-23-2005, 05:00 AM
AllMaxxedOut's Avatar
Nitro is right. When I put in my head unit/system, I spliced the blue write to allow the antenna to stay up when the radio is on and when I'm using the cd player.
AllMaxxedOut is offline
Old 01-23-2005, 06:15 AM
chenzarino's Avatar
Most new HU's have a wire for the power antenna, check your wiring again it should be a blue wire. If not, you gotta do it like they said, tap in to the amp remote.
chenzarino is offline
Old 01-23-2005, 07:03 AM
Cool Thanx Everyone I'll have to look @ that today
Old 01-23-2005, 07:43 AM
minsbang's Avatar
when i had my hu installed, my antenna would go up everytime I turned the power on. Then I had a switch installed just for the antenna.
minsbang is offline
AaronL
08-08-2020 10:31 AM
chisam14
11-06-2018 08:56 PM
BobTX10
10-07-2015 08:43 AM
dshinn
09-26-2015 08:07 PM
Quick Reply: Auto Antenna
