Am I missing anything before upgrading suspension?
Old Jan 24, 2005 | 10:24 AM
Armani
Hey. So I'm pairing up my suspension with H&R springs and tokico illuminas . I know there are some other items I need to replace/install when installing.
Please let me know if I'm missing any. (add to the list if you will)
1) KYB dustboots
2) shock bearings (I think that's what it's called)
3)...?
THank you all in advance.
Old Jan 24, 2005 | 10:27 AM
tavarish's Avatar
fwd gone rwd cr00
i've heard that the kyb dust boots are crap....just giving you a heads up.
I'm also going to upgrade my suspension, and I need to know what else I need for the spring/strut setup.
Old Jan 24, 2005 | 10:29 AM
mzmtg's Avatar
Minister of Silly Walks
New upper rear mounts from me
Seriously, the KYB boots are fine. Some of them tear, but they are still much nicer than OEM.
Old Jan 24, 2005 | 10:37 AM
zazon's Avatar
+1 to the rear mounts, you wont regret it, they are fantastic
Old Jan 24, 2005 | 10:39 AM
geo1317's Avatar
Yeah, definitely get the rear mounts, the KYB Boots and front bearings
Old Jan 24, 2005 | 10:42 AM
MDeezy's Avatar
same with me, i would also like toknow what is best to be done while inthere upgrading suspension.
any new bushings to replace?
also anyone have part numbers we can use also?
Old Jan 24, 2005 | 10:44 AM
NetFurie's Avatar
Also consider the front strut insulators while you have it apart. Mine busted at 110k and 130k. Makes a nice clunk sound when they're broke.
Old Jan 24, 2005 | 03:25 PM
Armani
so is the list complete?
1) KYB dustboots
2) front bearings
3) rear mounts
4) strut insulators (where can I get these??????)
Now, what about "rear bearings" and "front mounts"?
Old Jan 24, 2005 | 03:29 PM
geo1317's Avatar
1) KYB dustboots
2) front bearings
3) rear mounts
there are no rear bearings and as for the front mounts unless they are broken there is no need to change them, if you need to just get the OEM
Old Jan 24, 2005 | 04:03 PM
Armani
isn't it ok if I just get the OEM rear mounts? The ones mzmtg is selling are expensive: $75.
Old Jan 24, 2005 | 04:08 PM
ALC252DM's Avatar
True...might not be that much expensive over the oem ones but the benefits should be worth the money. I know my car needs them badly, plus my struts are all shot! Those mounts are almost necessary if your using lowering springs. That'll be next in the list after I get the clutch master and slave replaced in a few weeks.
Old Jan 24, 2005 | 04:35 PM
99SEL4ME's Avatar
I am also doing the Illuminas and H&R springs in about a month or so. So I have 106k on my 99SE-L, so I should also replace front strut mounts and insulators, and rear mounts? And dust boots if needed ? I guess if they go down the road, they will already be done. It's okay to just go with OEM ? Good thing someone posted this, because I would not have known to replace those things.
Thanks boys
Jeff
Old Jan 24, 2005 | 05:12 PM
mzmtg's Avatar
They aren't THAT expensive
If you arent going to get mine, don't get any.
The mount is just a stamped piece of metal, there's no reason to replace it. There's nothing to wear out.
Old Jan 24, 2005 | 05:43 PM
Armani
how do I go about ordering them from you? Also, do these really help the rear suspension travel as others have claimed?
Old Jan 24, 2005 | 06:07 PM
Terran's Avatar
Click on the huge red link in his sig .
Old Jan 24, 2005 | 08:04 PM
JSMax's Avatar
Sold
While you are at it, check your c.v. boots and the axle seals from the tranny to the driveshaft. If that stuff is bad, you've got everything apart, might as well fix it right then and there.
Old Jan 26, 2005 | 08:54 AM
MDeezy's Avatar
Final Answer??
NEW Struts and Springs (Ofcourse)
1) KYB dustboots
2) front bearings
3) rear mounts
4) strut insulators
what about control arm bushings? and sway bar frame bushings?
Old Jan 26, 2005 | 10:54 AM
96white's Avatar
i know this is a little off topic but when we do the suspension upgrade what do you torque the bolts to? ( how many foot pounds) and where?
thanks
Old Jan 26, 2005 | 11:01 AM
MDeezy's Avatar
the 2 main bolts attached to the bottom of the strut?
not sure which ones you need but
Originally Posted by http://vbxmaxima.8m.com/shocks.html
14. Align the bottom part of the strut and insert the two big screws. Torque down the bolts
to 103 to 117 ft-lbs.
15. Tighen the top three bolts to 29 to 40 ft-lbs. Tighten the center bolt to
43 to 58 ft-lbs.
Fbana41
Aug 29, 2016 12:18 PM
maxima-junky
Oct 7, 2015 06:13 PM
jerrod99_se-l
Sep 25, 2015 03:02 AM
A32goldylocks
Sep 2, 2015 06:39 AM
