need help car cranks but does not start
Old Jan 25, 2005 | 12:48 PM
staytuned24's Avatar
for some reason on saturday when it was cold my car cranked but did not start i had this problem since i bought a car i went through 3 starters so far and i think another is going I would appreciate any help i can get I think while cranking some signal is being lost in the harnest.
Old Jan 25, 2005 | 01:25 PM
Stephen Max's Avatar
Probably a sensor problem. Engine coolant sensor, cam position sensor and crankshaft position sensors can all cause starting problems when they go out.
Old Jan 25, 2005 | 01:49 PM
Viscous's Avatar
For me it was the cam position sensor. The car would crank and crank but would not start up. You should try pulling your codes to see if the ecu has anything for you. If you're not sure how to do that, read the stickies at the top. Good luck.
Old Jan 25, 2005 | 02:04 PM
G4nismo's Avatar
floor your gas pedal hold it and start it up
Old Jan 25, 2005 | 07:53 PM
Ant96GLE's Avatar
Flooring the gas pedal does nothing on a fuel injected car.
Check your crank sensors and cam sensor. You have 2 crank sensors, one under the main under drive pulley (REF) and one on the bellhousing (POS) You can take them off and just clean them off. They are magnetic and over time metal shards form on them and cause the signal to the ECU to get cut off. THe Cam sensor is the same thing, its located on the timing chain cover. They all send signals to the ECU at startup so the ECU knows the position of the crank and cam.
BTW are you part of the Stay Tuned crew on Eastern Parkway and Atlantic?
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
beboski
Aug 16, 2015 05:23 PM
Balkins
Aug 12, 2015 06:39 AM
