Programming a Remote
Old Apr 27, 2001 | 08:56 AM
cbock's Avatar
Does anyone know how to program a remote. When I bought my Max it only had one remote. I am thinking of buying an extra one.
Old Apr 27, 2001 | 09:01 AM
Sonic's Avatar
From MaxFAQs:
Q: How do I reprogram the Keyless Remote?
A: Here's the procedure from the 1995 Factory Shop Manual
Replacing Remote Controller or Multi-Remote Control Unit (LCU05)
Enter the identity (ID) code manually when:
remote controller or multi-remote control unit LCU05 is replaced.
an additional remote controller is activated.
ID Code Entry Procedure
To enter the ID code, follow this procedure.
Entering "Setting mode":
(1) Close and lock all doors.
(2) Insert and remove the key from the ignition more than six times within 10 seconds. (The hazard warning lamp will then flash twice.) At this time, the original ID codes are eliminated.
ID code entry:
(3) Turn ignition key to "ACC" position.
(4) Push lock button on the new remote controller once (for example, if door is locked using the remote controller during this ID code entry enable state, a new ID code can be entered). At this time, the new ID code is entered. (The hazard warning lamp will then flash twice.)
Additional ID code entry
(5) If you need to activate additional remote controllers, unlock the driver's door, then lock again with door lock ****.
(6) Push lock button on the additional new remote controller once.
(7) This ID code entry enable state and setting mode remain until the driver's door is opened.
NOTE
If you need to activate more than two additional new remote controllers, repeat the procedure "Additional ID code entry" for each new remote controller.
If the same ID code that exists in the memory is input, the hazard warning lamps will flash twice but the entry will be ignored.
Entry of maximum four ID codes is allowed and any attempt to enter more will be ignored.
Any ID codes entered after termination of the "setting mode" will not be accepted. Additionally remote control signals will be inhibited when an ID code has not been entered during the "setting" mode.
Old Apr 27, 2001 | 09:20 AM
cbock's Avatar
Thanks medicsonic!
Where is the MaxFAQs you are referring to? I looked in the Maxfaqs here and didn't see it listed.
Old Apr 27, 2001 | 09:26 AM
Sonic's Avatar
http://web2.airmail.net/scutchen/max_faq/
Another excellent site is Cheston's, known here as Chebosto. His site is www.maximadriver.com . Other members have good how-tos on their websites also.
Old Apr 27, 2001 | 09:31 AM
cbock's Avatar
I've been bookmarking maixma sites for a couple of weeks. I had www.maximadriver.com but not the other one. There's lots of good info out there if you know where to find it.
Thanks again medicsonic.
Old Apr 27, 2001 | 06:00 PM
BobMax's Avatar
I don't suppose there's a way to do this with a new key ?
I really don't like paying the dealer $34 to (re)program the keys... any secret incar procedure for this ?
Bob
Old Apr 27, 2001 | 06:38 PM
Sonic's Avatar
Got me.
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
maxinout93
Oct 16, 2015 02:53 AM
ToTheMax305
Sep 23, 2015 09:11 PM
flu2000
Sep 14, 2015 12:34 PM
intimidator
Sep 5, 2015 07:23 PM
