Timing Chain Replacement
Old Jan 30, 2005 | 10:18 PM
Kenny302's Avatar
How much would I expect to pay to have my timing chain replace? How hard is it to do it myself? I'm in a jam right now, and I need some info quick. Any help would be greatly appreciated.
Old Jan 30, 2005 | 10:27 PM
s0ber's Avatar
Why are you replacing your timing chain???
SPiG's Avatar
SomePsychoGuy
The timing chain should last the life of the engine. It should never need to be replaced unless it is broken. I am not sure how to do it though.
Old Jan 30, 2005 | 11:33 PM
tavarish's Avatar
fwd gone rwd cr00
sell your car, and get another one.
Old Jan 30, 2005 | 11:41 PM
Kenny302's Avatar
I had starting problems and brought the car to the mechanic, and they told me that the timing chain tensioner went bad, and caused "other problems" and that I need to change my timing chain....
Old Jan 31, 2005 | 08:30 AM
SPiG's Avatar
SomePsychoGuy
Your timing chain tensioner may be bad and while you are in there you could replace the chain but it is not absolutely necessary.
http://forums.maxima.org/showthread....t=timing+chain
http://forums.maxima.org/showthread.php?t=354751
http://www.vqpower.com/v2/modules.ph...howpage&pid=73 (for water pump but you have to remove timing chain tensioner to get to it and it has pics)
Mine kind of grinds on cold starts but goes away. I may eventually replace it. I don't see how that would make starting problems though unless timing was off.
Old Jan 31, 2005 | 08:37 AM
max'dout06's Avatar
probably expensive - it takes time to get to the timing chain - if it needs to be replaced - and if they are charging by the hour - it's not cheap..... just my .02
maxinout93
Oct 27, 2015 01:29 PM
stromm
Aug 27, 2015 04:13 PM
erictown
Aug 20, 2015 08:01 AM
Balkins
Aug 12, 2015 06:39 AM
Tanvirkamal
Aug 5, 2015 01:32 AM
