Hit pach of ice, kissed a curb, bent control arm, need advice!
Old Jan 31, 2005 | 06:02 AM
Whitemax's Avatar
Disco Biscuit
So I was driving the gf's car sat night to dinner and we hit a patch of ice and slid into a cub, pushing the front left wheel back about 3 inches. After looking at it yesterday, it doesnt look like the strut is bent, and it still turns fine until the wheel hits, so I'm thinking and hoping that the only damage is the bent control arm. I've found some used ones nearby for cheap ($35) I've looked at the Haynes manual and it looks like a fairly straight forward job. Has anyone had this happen before? What was damamged? How much did it cost to repair? Is this something I can swap out myself with some help?
Old Jan 31, 2005 | 06:20 AM
mzmtg's Avatar
Minister of Silly Walks
The only sticky part of a straight control arm swap is seperating the ball joint. The rest is cake.
Old Jan 31, 2005 | 06:26 AM
Whitemax's Avatar
Disco Biscuit
Ya I noticed that too. They said not to use a "picklefork" becuase you'll damage the boot, but to use a crowbar or big screwdriver....
Old Jan 31, 2005 | 06:31 AM
mzmtg's Avatar
If you aren't concerned with preserving the joint on your bent control arm, there's no reason not to use a pickle fork to seperate it.
Old Jan 31, 2005 | 06:35 AM
Whitemax's Avatar
Disco Biscuit
Dumb question, but I asume that the other control arm will have a ball joint already on it?
Old Jan 31, 2005 | 06:54 AM
njmaxseltd's Avatar
The trick to seperating a ball joint is to hit the sides of the receiver nice and hard with a hammer. That will squeeze the joint slightly and push the tapered shaft out. Do that while applying force to seperate the joint and it should pop right out easily.
Old Jan 31, 2005 | 10:18 AM
slizan99's Avatar
for the hammer and not the picklefork advice.
Old Jan 31, 2005 | 04:07 PM
Mishmosh's Avatar
The new control arm with have a new ball joint. Forget about babying the old one....
Old Jan 31, 2005 | 04:26 PM
PAREDLINE's Avatar
$35 for a control arm is ridiculously cheap. Something's up with that. I'd get one from pinnacle nissan just to make sure you're not driving down the road and your wheel flies off like you see with a lot of fords. A decent aftermarket control arm should run about $70. You pay for what you get and a control arm is not where you should try to cheap out. In my opinion of course
Old Jan 31, 2005 | 06:16 PM
Whitemax's Avatar
Disco Biscuit
Well, its a used control arm, not new, and they have 5 or 6 of them.
Old Jan 31, 2005 | 06:18 PM
Jeff92se's Avatar
I'm needing a caw
Put a new ball joint on. Best to do now. Consider a new tie rod also. Also maybe consider pressing in new bushings for the control arm.
Old Jan 31, 2005 | 06:19 PM
jdmmax's Avatar
just hit the side of the ball joint reciever with a metal mallet a few times it will come loose.
Old Jan 31, 2005 | 06:58 PM
internetautomar's Avatar
mod or sell?
just buy a new arm, it's a few bucks more but they will normaly come with a new ball and new bushings.
at least the ones I sell do
Old Jan 31, 2005 | 08:41 PM
Cutler's Avatar
Get a new assembly with new ball joint and bushings
AcuraLegend
Oct 17, 2016 08:47 PM
Starrider
Dec 18, 2015 04:43 AM
AcuraLegend
Sep 22, 2015 04:22 PM
EdRomo86
Sep 12, 2015 07:49 PM
dcam0326
Sep 8, 2015 11:02 PM
