programming instructions for 96 maxima gxe remote?
Old Feb 1, 2005 | 02:32 PM
macmood's Avatar
does anyone have the instructions on programming a 1996 maxima gxe remote?
Old Feb 1, 2005 | 03:09 PM
Black Maxima
I've bought new keyless entry remotes for my car, how do I program them?
Replacing Remote Controller or Multi-Remote Control Unit (LCU05)
Enter the identity (ID) code manually when:
-remote controller or multi-remote control unit LCU05 is replaced.
-an additional remote controller is activated.
ID Code Entry Procedure
To enter the ID code, follow this procedure.
Entering "Setting mode":
(1) Close and lock all doors.
(2) Insert and remove the key from the ignition more than six times within 10 seconds. (The hazard warning lamp will then flash twice.) At this time, the original ID codes are eliminated.
ID code entry:
(3) Turn ignition key to "ACC" position.
(4) Push lock button on the new remote controller once (for example, if door is locked using the remote controller during this ID code entry enable state, a new ID code can be entered). At this time, the new ID code is entered. (The hazard warning lamp will then flash twice.)
Additional ID code entry
(5) If you need to activate additional remote controllers, unlock the driver's door, then lock again with door lock ****.
(6) Push lock button on the additional new remote controller once.
(7) This ID code entry enable state and setting mode remain until the driver's door is opened.
NOTE
If you need to activate more than two additional new remote controllers, repeat the procedure "Additional ID code entry" for each new remote controller.
If the same ID code that exists in the memory is input, the hazard warning lamps will flash twice but the entry will be ignored.
Entry of maximum four ID codes is allowed and any attempt to enter more will be ignored.
Any ID codes entered after termination of the "setting mode" will not be accepted. Additionally remote control signals will be inhibited when an ID code has not been entered during the "setting" mode.
Linkage: http://home.earthlink.net/~maxfaq/m...ance.htm#Remote
Credit: Spritemax
#40, right from the 4th Generation FAQ sticky.
ah2002
Mar 9, 2016 01:42 PM
Ray229Harris
Sep 16, 2015 08:16 PM
kirkhilles
Aug 8, 2015 10:53 AM
maximaham
Aug 7, 2015 01:11 PM
13Maximasv
Aug 7, 2015 10:56 AM
