drop looks wrong
drop looks wrong
I have a 96 and dropped it, KYB struts shocks and eibach coilovers used, i put them on my car and the drop was shady, i was then informed that my friends car a 97 the drop was way lower anyway its as low as can go does anyone have any ideas!????????????...
Ground Controls coilovers use Eibach springs. I think GC is a subdivision of Eibach or are related somehow.
Are you using GC coilovers or Eibach springs? With coilovers you can adjust ride height and make your car lower. Just wondering Which KYB struts are you using, GR2s or AGXs?
Eibachs are not really that low, about 1.5" or so. They are really stiff though, one of the best handling springs. I love mine. It looks like a max should stock. If you have Eibach springs then you would have to get lower springs or some kind of coilovers.
http://maxmods.dyndns.org/index.php?MaximaHandling
How can a drop look shady?
if you have coilovers you can adjust the height....you can lower a car on GCs more then springs.
what is this setteling stuff? my sprints didn't settle.
as far as i know my buddies GC didn't settle either...
if you really want springs, sprints are the only one that are really low...
Originally Posted by flyby
yeah thats problably it, i guess it'll settle by the way kyb agx, im going to give it a couple weeks if i see no improvement then i was thought bout just switchin to springs what do you recomend
Originally Posted by I30tMikeD
I recomend typing in compelete sentences and anwsering the question that were asked.
Do you have coil overs? if so you dont need to buy new springs just adjust the height
on a side note:
S-Tech are low also 2" drop.Should rock well on AGXs
Tien S techs and sprints are the lowest drops for springs.
Coilovers are needed if you want to be really low. You cannot be "tucking" on springs. Not going to happen. Maximas are too high to begin with to do that.
Originally Posted by h2kSPiG
What setup does the 97 have? There shouldn't be a huge difference. 97s are a little heavier. Autos are also heavier so the front will drop more on an auto.
1) Springs do not settle
2) coil overs can be adjusted
3) There is no difference in suspentions from 95-99
4) Eibach prokit springs look like this
You can go lower but on stock style struts it will not handle any better. Some sprint owners just about tuck BTW.
Forge277
06-13-2016 09:26 PM
maxima-junky
10-07-2015 06:13 PM
bigfrank
10-01-2015 12:51 PM
