adding heated seats and mirrors
Old Feb 1, 2005 | 08:03 PM
Blackwind's Avatar
well the title says it all. i have a 98 black on black se. and its got every thing except, woodgrain (which will come later),heated seats and mirrors,amb button,and lsd(comming soon).
my main question is what will i need to get either from a yard or dealer to make the mirrors and seats complete. i know the elements for the seats and the mirrors, buts are there any special boxes or anything else i should pick up?
it does not look like a task too hard to acomplish, any thoughts are welcome.
navfe-
Old Feb 3, 2005 | 01:44 AM
Maximathug's Avatar
I'm trying to do the same thing, I was told that all of our car come pre wired for all the options so you will need to go looking for any tucked wires and it should be plug and play for the most part. The next thing you would need is the wiring dsgrams, if you have the Haynes/Chilton books just look in the back and follows the electrical diagrams. I am interested in the mirror elements in particular did you get them from the dealer or do you know a good place to get them let me know. dee_mil_2000@yahoo.com
Old Feb 3, 2005 | 07:18 AM
Blackwind's Avatar
i asked at the dealer yesterday, options like this were supposedly added at the port when the cars arrived in the states.
anyone have any idea if this is true?
Old Feb 3, 2005 | 07:44 AM
Jatan's Avatar
The heated mirrors turn on with the rear defroster, but your car should be prewired. Take off one of your mirrors and you should only have one wire connector on your mirror (see pic: http://cgi.ebay.com/ebaymotors/ws/eB...category=33649) but the heated ones have two connectors (see pic: http://cgi.ebay.com/ebaymotors/ws/eB...category=33649) so just check to see if you will be able to plug in both connectors (you should). I'm not sure if there is a seperate fuse or if it uses the same one from the rear defroster (or maybe it needs a bigger one) but you'll have to look into that.
The connectors for the seats plug in under the seat on the floor (check and see if it's prewired) but you might have to do the wiring on your own. If it's prewired then you'll need to connect the seats to the connectors on the floor and then connect the heated seat switches to the wiring harness (the switches go right between the hand brake and arm rest - looks like little coin holders) and then add a fuse or something If it's not prewired for the seats then you'll have to do the wiring on your own (I think a few people have done it)
Old Feb 3, 2005 | 07:26 PM
Blackwind's Avatar
thanks for that. ill look into it.
Old Feb 3, 2005 | 08:51 PM
Nismo98's Avatar
Please post something when you get any info of heated mirrors.
Andrei
Old Feb 3, 2005 | 08:55 PM
tavarish's Avatar
fwd gone rwd cr00
how would i know if my car has heated mirrors?
Old Feb 3, 2005 | 09:04 PM
Nismo98's Avatar
I am sure that the dealer can tell you that by your vin, or you can take off one of the mirrors as see how many plugs it has.
Andrei
Old Feb 3, 2005 | 09:22 PM
Jatan's Avatar
Splash some water on your mirrors and turn on the rear defroster. If the mirror drys up then you have heated mirrors (the mirror will feel a little hot when you touch it) or you can see how many connectors there are
I think the heated seats and heated mirrors came in the cold weather package so if you have one then you have the other (not 100% sure about this tho )
Old Feb 3, 2005 | 10:26 PM
Blackwind's Avatar
that much i know is truth.
Old Feb 4, 2005 | 10:50 AM
It was part of the cold weather package. Part of the cold weather package was side air bags in the seats. Wierd, but true. So, look on the sides of your seats for a big "SRS" in a dark grey piece of plastic.
James
tarun900
19
Dec 20, 2021 06:57 PM
Fbana41
Aug 29, 2016 12:18 PM
sliptap
Sep 30, 2015 05:57 AM
jaydot901
Sep 29, 2015 01:18 PM
Max Nu-BE
Sep 28, 2015 10:25 AM
