Proud owner of a BLOODY STUMP!changed ks...
Old Feb 2, 2005 | 12:48 PM
thefed's Avatar
So i did it - took about 45 minutes and a little blood. But I changed my knock sensor. All I did when I finished was reset the ECU, and ride up and down my street 3 or 4 times. I seem to have more low end torque.
BUT...why isnt my ghost code disappearing? I reset the ecu (clockwise,2sec,counter,2 sec,clockwise,2sec,counter), but its still on. Do I need to drive a while?
Thanks 4 ur input....
Old Feb 2, 2005 | 12:54 PM
Stephen Max's Avatar
Sometimes it is the knock sensor harness that needs replacing.
Old Feb 2, 2005 | 01:01 PM
thefed's Avatar
if its the harness...wouldnt I NOT notice the difference? does it take some time to go away or what? even when i reset the ECU, then power off the car, power on the car (power, not start it)and check again, , the code remained!?!? this is after driving a mile or so with the new sensor
maybe im not resetting it right? i read the info on resetting, seems pretty simple...i explained how i did it in my first post...
Old Feb 2, 2005 | 01:08 PM
knight71's Avatar
Are you getting only 0304 and another code with it?
Old Feb 2, 2005 | 01:12 PM
Butt dynos can be deceiving, although when I changed my KS there definitely was a noticeable increase in power.
When you reset the ecu, did you follow the procedure at the bottom of this page:http://vbxmaxima.8m.com/ecu.html
Old Feb 2, 2005 | 01:16 PM
thefed's Avatar
I "only" get ks code, and yes, that's how i reset it. ima go drive for 10 mins and see
Old Feb 2, 2005 | 01:24 PM
Vaudeville Villain's Avatar
Keep driving.... "up and down the street 3 or 4 times" - does that mean you put 30 miles on it or 3? I believe it can take a while for the ECU to return from safe mode...
Old Feb 3, 2005 | 09:05 PM
vettefever5's Avatar
after i replaced mine i'm pretty sure after i reset the ecu it didnt come back on. i read that it takes a little while for the engine to recognize that theres a new ks because it increases the timing very very little until it gets knock, eventually it advances it as far as it can go.
Old Feb 3, 2005 | 09:26 PM
Jepht20's Avatar
Custom User Title...
perhaps you overtightened it or didn't tighten it enough?...
mine disappeared right away and hasn't come back even if i have other codes. i didn't feel an increase in power but the code went away and my gas mileage improved slightly(just a little).
Old Feb 4, 2005 | 08:12 AM
knight71's Avatar
I remember mine was still there too, however I retightened it and it went away.
Old Feb 4, 2005 | 11:29 AM
XeroX's Avatar
Hella internets
if it is the harness...how much do those run?
Old Feb 4, 2005 | 11:31 AM
Not much, about $20.
Mar 12, 2020 12:06 AM
doctorpullit
Jul 20, 2019 09:31 PM
RWCreative
Sep 21, 2015 11:01 AM
flu2000
Sep 8, 2015 02:23 PM
