RPM dropping to 500
For the low idle, try cleaning out your throttle body, if that does not do the trick, clean out the IACV (Idle Air Control Valve). Also for the loss of power, check you ECU for stored codes, you may pull up a Knock Sensor code.
Here is a link that shows a picture of where it is, look at post #3. It is behind the throttle body and in is connected to the intake plenum.
http://forums.maxima.org/showthread.php?t=257492
Unclejunebug
04-02-2016 06:42 AM
maxima-junky
10-07-2015 07:13 PM
Need help
23
10-02-2015 09:56 AM
