Does My Slave Cylinder need to be replaced or something else? *pics*
I was checking my Oil today and i noticed there was some brake fuild on my transimission so i took some pictures. I am guessing it is the Slave cylinder and that fluid just ran down the line and pooled on the transmission housing. Does this look like its my slave cylinder leaking.
I checked the fluid level and it is over the MAX line so its not very bad but my question is this normal. Also it is difficult to get into gear sometime but for the most part it is not too bad
Looks like it's just the hose. This can prevent your clutch disk from fully disengaging, causing hard shifts.
When the slave cylinder goes, you will see fluid coming out where the pushrod is (part w/the boot).
Could i use this line as a replacement.
Originally Posted by zack342
I do have hard shifts sometimes but i thought it was due to weather. thanks for the info. I think i am going to purchase a new slave cylinder and replace it at the same time.
10 chars.
thanks for the info guys. i am going to go ahead and order one of those lines and a new nissan clutch slave cylinder(3062031U61) since the system will be bleed anyway.
You dont have to replacet he slave cylinder if you are going to bleed the system. If you want to renew your slave cylinder, I suggest you buy a rebuild kit, (it comes with the internal cylinder and rubber boot.) It only costs about $5 on rockauto.com.
i think i will just replace the who thing. I will just do it an be done with it.I think it will improve the feel of things and make driving more pleasent.
But so i am positive the line darrick is selling is the line i need to replace? correct.
i guess its the line is what is leaking after all. I have read the entire thread for the stainless steel line group by and i atill do not know if that line is the same as the one i need. can anyone confirm this please i would like to order it.
i also found this
http://www.motorvate.ca/mvp.php/802
i also found this
the group buy
http://forums.maxima.org/showthread.php?t=338081
vingodine
45
May 21, 2016 12:46 PM
[/QUOTE]
