95 Maxima GLE Start Engine in Cold Weather
Old Feb 10, 2005 | 12:31 PM
Horace's Avatar
Hello,
When I start my engine in cold weather, I have to step on the gas pedal in order for the rpms to not drop down and have to restart. Is this normal? I don't think so, but I'm not good with cars. Anyone have any idea what is wrong if it is not normal?
Horace
Old Feb 10, 2005 | 12:34 PM
dennisadhs's Avatar
I have the same problem... anyone know whats up?????
Old Feb 10, 2005 | 12:38 PM
lilaclucymaxima's Avatar
Team Ramrod
happened to me... first of all, doing this will cause your starter to go so be ready to buy a new starter afterwards possibly. it was my engine coolant temperature sensor in combination with bad fuel injectors... in your case it is prolly just the engine coolant temperature sensor though.
Old Feb 10, 2005 | 06:13 PM
dennisadhs's Avatar
How much does this sensor cost?? Also how is it when installing it?
Old Feb 10, 2005 | 06:20 PM
Team Ramrod
very easy to install. $27 from dealer. took me about 5 minutes to install it, and thats only cuz it was 25 degree weather
Old Feb 10, 2005 | 06:29 PM
dennisadhs's Avatar
awesome thanks for the information
Old Feb 10, 2005 | 06:58 PM
3Mar67's Avatar
Is it possible to require a new coolant temp. sensor even if your car shows no code or check engine light?
Old Feb 10, 2005 | 07:00 PM
tomservo291's Avatar
It's also possible it's just a dying battery. How old is it?
If it only happens in cold weather this is a likely culprit -- I had to get a new one (I think mind still had the original battery from dealership) at the beginning of this winter when it was like -2 for a few days straight, battery **** the bed and wouldnt even start one day.
But it never showed any signs of wear until it was cold outside.
Old Feb 10, 2005 | 07:19 PM
grave_digger500's Avatar
this happened to my 4th gen, and i had a brand new battery
i would have to keep my foot on the gas for a second to keep the engine from dying
i thought it was a computer problem, got scared and sold the biotch
Old Feb 10, 2005 | 08:13 PM
acmax95's Avatar
I had the same problem on my 95. I thought it was the battery also. I replaced it but that wasnt the problem. I ended up going to the dealer.and they said the idle was too low. It ended up costing about $160 but it solved the problem
Old Feb 11, 2005 | 04:25 AM
dallas0593's Avatar
Coolant temp sensor
Old Feb 11, 2005 | 04:32 AM
chiwchan's Avatar
Its the idle air control valve, nneds to be cleaned..... I'm sure of this...
Old Feb 11, 2005 | 05:27 AM
It can be any of the things mentioned here -- all of which can be remedied or tested with about 2 hours of effort.
Clean your IACV and your throttle body (which probably needs to be done anyways.) Goto autozone or some place like that and have them test your battery. If you clean those, and the battery is fine, then you might want to have it checked out. But do that first, it will cost you all of $2.99 for the TB cleaner.
CRizz
41
Jun 7, 2021 05:42 AM
maxinout93
Oct 27, 2015 01:29 PM
02PearlSE
Oct 7, 2015 02:12 AM
acw
Aug 13, 2015 12:50 AM
Balkins
Aug 12, 2015 06:39 AM
