New suspension, same problem
Old Feb 14, 2005 | 06:40 AM
Kehops's Avatar
My old suspension was shot so any little bump in the road I would get a thumping sensation through the steering wheel. I recently changed the suspension to Tokico springs w/ Illuminas which makes the handling 10x better than before, its great, however when hitting reasonable cracks in the road or "sharp" bumps, I can still feel it through the steering, same sensation as before. The susp. seems to be doing a great job for overall driving but when hitting potholes or even little cracks, I feel it thumping. What else could be looked at and replaced to make the ride as smooth as possible?
Note: it seems to be even harsher when hitting cracks or bumps while turning, if that helps.
Old Feb 14, 2005 | 07:44 AM
DragonMaxima's Avatar
Try playing with the settings.
Lower the number the softer the suspension.
Old Feb 14, 2005 | 07:46 AM
lewtion1's Avatar
same problem here... mechanic is not even sure what else to check out anymore. oem springs, GR2's all around, new strut bearings.
BUMP BUMP
Old Feb 14, 2005 | 07:48 AM
Kehops's Avatar
Ya I already tried this, no difference.
Anyone?
Old Feb 14, 2005 | 10:10 AM
njmaxseltd's Avatar
Worn out lower control arm bushings might cause that.
Also, what were the upper mounts like?
Did you check the sway bar end links when you put your new suspension in?
Retorque the subframe bolts & check the rack & pinion mounts.
Old Feb 14, 2005 | 10:18 AM
Kehops's Avatar
The upper mounts looked good. I did notice one of my bushings on the control arm seemed a little out of place compared to the other side. Correct me if I'm wrong but the whole control arm needs to be replaced right? No way of changing just the bushing(s)?
I'll double-check my sway bar end links tonight, I didn't really notice anything out of the ordinary when we installed it.
Old Feb 14, 2005 | 10:27 AM
A Flood99's Avatar
welcome to the maxima's suspension
Old Feb 14, 2005 | 10:33 AM
Kehops's Avatar
Welcome to worthlesspostville
My Max did not ride like this when I bought it, so obviously somthing can be repaired.
Old Feb 14, 2005 | 10:35 AM
illmortal's Avatar
you dont have to replace the whole sway bar, just the bushings.. if you're gonna replace the sway bar, look for an aftermarket (thicker mm)
Old Feb 14, 2005 | 10:37 AM
Kehops's Avatar
re-read my post. Not sway bar, control arm
Old Feb 14, 2005 | 01:44 PM
illmortal's Avatar
well only if the control arm is damaged/rusted then you should, but you dont have to fix something that doesn't need fixing. So just replace the bushings.
Old Feb 14, 2005 | 04:16 PM
njmaxseltd's Avatar
That bushing out of place is probably the cause of your noise. They can be replaced seperately but sometimes it's not worth the effort. See if you can find a source online for a new control arm. It should come with a new ball joint as well. That would be the easiest way out.
Old Feb 14, 2005 | 04:25 PM
A Flood99's Avatar
not to be negative or anything, but i'll bet that you never get your max riding the same as when you just bought it
Old Feb 14, 2005 | 04:48 PM
nick's Avatar
Ahhh, the dreaded topic of too much "road feel" I have the same problem ,my wheels are balanced and the steering wheel does not vibrate at any speeds , but there is so much unwanted road feel - every little crack or bump in the road is felt through the steering wheel , which throws out the whole driving experience of the car.
I have been trying to correct this problem for over 1.5 year now, with no luck
I have all thge suspension parts replaced : new struts, bearings , mounts, end link and sway bar bushings , like 6 alignment in past year, even riding on stock Se springs didn't help.
next think on my agenda in replacing stering rack bushings, repalcing the entire steering rack along with new inner tie rods and i might have to replace one control arm
if all this doesn't help - he is going to chop shop on the south side of Chicago.
Nick.
Old Feb 14, 2005 | 04:55 PM
illmortal's Avatar
Nick.
lol to be honest I wouldn't even bother with all that... by the time you're done spending all that money you could have purchased/leased a used G35
Old Feb 14, 2005 | 05:00 PM
nick's Avatar
very well said , thank you, I just wish it would be that easy - i'm very nit picky with my car - everything has to work and function just right ,
but with car that is almost 9 years old with 145k it is quite a challenge
she is still fighting though....
Nick.
Mar 12, 2020 12:06 AM
mikeg75
Nov 30, 2015 05:12 PM
Violator
Sep 9, 2015 10:14 AM
slowlifer
Sep 8, 2015 05:53 AM
A32goldylocks
Sep 2, 2015 06:39 AM
