Chocolate Milk In Engine
I saw a sort of milky substance like chocolate milk when I looked into the oil cap. I called a shop and they said it was anti-freeze that is getting into the engine. Does anyone know what is causing this and how to fix this?
if you leave it like that it will seriously damage your car, i had to replace a motor in my old car for the same reason. easier to replace the gasket than to replace the engine. (blew gasket before i knew anything about cars)
Its Normal, wipe it off and I garentee it wont come back..
-matt
Originally Posted by matty
If you only saw it ON the Oil cap I think thats ok..Thats moisture that was trying to escape.. I also get that but only in the winter. I used to get it on my Jeep and my mom gets that on her Jetta...
-matt
-matt
Nope it's all in there like someone jizzed in it.
Originally Posted by suicidalspd99
it could also be a cracked head. if i were you i would put a nice 3.5 in it.
Unfortunetly it would probably be best to get another motor. It's highly likely that your engine needs a serious rebuild and it probably isn't worth the cost over getting another motor. A 3.5 swap would be nice but it's costly in terms of both time and money, and from what I understand there are still bugs being worked out in this process.
If it was me and this was for a daily driver I'd swap the motor with another VQ30 and then rebuild my original on a stand in the garage, and do some upgrades while I have it apart.
In any case your engine is rather buggared. It would be nice to put a 5th gen motor in it, but that's going to take extra time and/or cost a good bit of extra money. If they were quickly & easily swappable like that then it would be better, but unfortunately they ain't!
BTW have you had the car overheating lately or anything?
Tightening is a nice thought, but not how it works. I think a weakness in the gasket gets exposed over time from the internal pressures and eventually blows out. It may be in the initial stages of doing so and leaking into the engine, but at some point it will blow and your engine will overheat quickly.
Don't scrap what could be a perfectly good engine because of quick quips over one symptom though. If you drive a lot of short trips, especially during colder weather, then I think it's possible that it could be condensation build up in your engine. Whatever it is, you need to find out why, soon. If you drive it too long with an internal leak problem, a new engine may be the only option and not just one of them.
Plus it's easy for guys who aren't paying for it to suggest it. Paying for someone else to take out and put in a new engine isn't near as cheap as having a head gasket replaced. Unless you're one of these guys who can do it yourself and go without transportation for a month while you're doing it after work and on weekends while taking the bus. I'm guessing you don't have that option.
Good Luck.
Good Luck.
Originally Posted by Nismo3112
it will most likely be cheaper to replace the entire engine instead of having the work done. Our engines cost pocket change.
theshawn is right:
This sucks. Its not like changing a tire. Well I'll take to the mechanic and see what he has to say. I dont have the capability to change the engine myself. So I'm guessing that the mechanic would probably charge me about 12 man hours to do it.
The car has been driven over 500 miles like this. I have a 100 mile commute (round trip) I dont think it's condensation. The check engine light is on. I'll check the code. The car has not been overheating, but I have noticed that one of the anti-freeze rubber tube is leaking at the connection to the radiator.
shilov
02-19-2024 09:40 PM
James92SE
142
01-02-2024 09:23 AM
