Any bolt-ons left? Have I maxed it out?
Old Feb 18, 2005 | 11:02 PM
Spaniard's Avatar
Have I maxed out the Max in the performance category? ( For a track setup - Autocross/HPDE)
I have asked this question before, but Im always looking for new/good info from the org-
Ive done (or have scheduled) the following:
MEVI (! Finally !)
JWT ECU
Stillen B-Pipe
Stillen Y-pipe
Stillen Muffler
Stillen Front Strut Tower Brace
Stillen Rear Strut Tower Brace
Stillen Rear Sway Bar
5 lb Aluminum Flywheel
ClutchNet Kevlar clutch disk
Stainless Steel Brake lines
Hawk HP+ Brake pads front
Metal Matrix Rear brake pads
Eibach Springs
Brembo Bianchi Slotted-Cross Drilled rotors
Koni Yellow Adjustable Shocks
Rota Slipstream Rims 15x6.5 (12 lbs)
Unorthodox Racing Underdrive Pulley
Warpspeed Metallic Substrate Hi-Flow Cat
Negative camber bolts in front struts (Eibach kit from TireRack)
2.1 / 2.2 degrees negative camber
Custom "RAM" AIR intake (yea yea, debatable)
K+N Air Filtering
NGK Copper plugs
Batcap 800 battery (13 pounds)
Hyper-Grounding Kit
Short Throw Shifter
I guess the other mod that might be interesting is Pathfinder TB? What could I expect given everything else?
Ive already done about as much weight reduction as possible, down to 2900 lbs.
Any suggestions? Im not gonna go Nitrous or Forced induction methinks.
Old Feb 19, 2005 | 01:47 AM
SPiG's Avatar
SomePsychoGuy
I will just throw cams out there but IDK if you want to go that route.
LSD if there is a way to get a quaife or some other quality one
motor mounts
A few suspension things like LTB, SFC, polyurethane bushings
Old Feb 19, 2005 | 02:08 AM
Spaniard's Avatar
motor mounts
Whats LTB and SFC?
And how much can I expect to gain with Cams? And is it across the whole RPM band? Im thinking it would be expensive to install too (not gonna do it myself)
Thanks for the suggestions-
Old Feb 19, 2005 | 02:15 AM
Ceasars Chariot's Avatar
Old Maxima Legend
look at all those mods ! i think that is going to cover it, if you are sticking with the mevi , you could try extrude honing the mevi. i still may have the usim extrude honed not sure.
i need your rims, hey what about your interior, you could toss out the interior and put in a 20 lbs race seat and harness !!
Old Feb 19, 2005 | 06:01 AM
Terran's Avatar
LTB=lower tie bar. Made by blehmco (matt93SE).
SFC=sub-frame connectors. Made by warpspeed.
Cams will add to the upper RPM range. They're about a grand to buy and another grand to put it.
If you're willing to do some custom work then you could put in an '00 VI instead of the mevi and get more lowend and keep the top end.
A brake upgrade I would think would be quite helpful for the kind of racing you do. On the cheaper side of things there are matt93SE's 300zx caliper/2k4 rotor upgrades, jeff92se's 300zx caliper/mustang cobra rotor front only upgrade, and Veequeue's (sp?) 2k4 rotor and caliper front upgrade (only the front has been done, but the rear may very well be doable as well).
Old Feb 19, 2005 | 09:52 AM
Spaniard's Avatar
I'd like to upgrade the brakes but - I am hooked on my 15" rims (with the corresponding cheaper and often lighter tires) and kind-of-light rotors. So I am just now upgrading to SS brake lines and Hawk HP+ pads for an added bit of stopping power (I hope, anyway).
After trying to do everything to make the max accelerate faster, it would kind of hurt to add unsprung rotational weight -besides, by personal preference I brake early and more moderately, to avoid the worst kind of problems (finding a ditch on the side of the track)
Im not into major work unless the results are phenomenal. So cams, 00vi, and PF TB probably arent in the upgrade path..
Perhaps I should go to urethane bushings next.
Looks like warpspeed is updating their subframe connectors, gotta check back on that. - "easier installation"
More questions to this thread's distinguished participants:
Anyone know if:
A) the LTB stage 1 or 2 - is lightweight?
B) Subframe connectors stage 2 (non-weld application) can be done w/o stage 1?
C) Exhaust Wrap will make for a reduction in sound? (I gotta make it quieter by March 1)
D) Can anyone confirm that PF TB wouldnt be that great a gain - with n/a - even though I should have the MEVI going?
Old Feb 19, 2005 | 09:58 AM
Nealoc187's Avatar
SLOW
LTB is probably 10lbs from looking at it, maybe 15.
No you cant bolt stage 2 on without stage 1. Stage 1 is worth far more in performance than the very slight 20-25lb weight increase.
I don't think anyone has noted anything spectacular from a PF TB without FI.
A turbocharger does attach to the car with bolts!
Old Feb 19, 2005 | 01:11 PM
MaxGordon7's Avatar
what about headers? With all those mods, im sure heads about add a bit more and even better sounding.
Old Feb 19, 2005 | 01:28 PM
DAVE Sz's Avatar
Hooooooonda.....
the 00vi would've been a better choice for a track car don't you think? You still have cattman headers available over the y-pipe. Like mentioned before, SFCs from warpspeed and the front brace from Blehmco.
Old Feb 19, 2005 | 01:52 PM
Xmax's Avatar
If you are going all motor, looks like your there, but if your planning to go forced induction, then you will never be done. There is always something out there just to squeeze that 1 extra hp from the motor.
Old Feb 19, 2005 | 01:55 PM
nissandrvr's Avatar
Definately need headers!
Old Feb 19, 2005 | 02:49 PM
hacim105's Avatar
Doesn anyone have the LTB stage 1 or 2? How is it? Do you feel a good difference? Could this help at all with wheel hop at the track?
Old Mar 15, 2005 | 06:43 PM
VQuick's Avatar
Chassis Freak
OMG, Spaniard, I know you do a lot of track racing, so if you don't have an LTB and SFCs you *need* to get them. They will make a world of difference. I have the LTB (stage 2) and it's basically like a FSTB except it makes four times the difference, and I've heard nothing but amazing things about the SFCs (which may not yet be available again; Warpspeed was doing a slight redesign). They're only $200ish and the extra weight is....well, worth its weight in gold. Plus the LTB and SFCs are adding weight at the very bottom of your Max which will help lower the center of gravity.
Old Mar 15, 2005 | 07:14 PM
Broaner's Avatar
2060lbs and falling...
+1 for VQuick's excellent post. I was very suprised to learn that you didn't have those things already. Also, bushings. Also, larger rims may be heavier but they allow you to carry speed in the turn much more. But would all these changes bump you into the next class? Since you want a track car, don't go FI. You'll never be "done" if you do.
Old Mar 15, 2005 | 10:30 PM
MrDicks95SE's Avatar
Offset Is Everything.
yeah on the LTBs and SFCs. i thought you wouldve already had those by now...
Old Mar 15, 2005 | 10:41 PM
maxgtr2000's Avatar
KH3 by popular demand
Grasshoppa, u still need bolt on supacharga
Old Mar 16, 2005 | 07:12 AM
C MAX's Avatar
hks ignition, nothing like a strong spark.
Old Mar 16, 2005 | 09:13 AM
i believe those things are freakin expensive.
Old Mar 16, 2005 | 09:31 AM
1FSTMAX's Avatar
big brakes, true coilovers, race tires, cams, bushings, turbo/sc, roll cage, build a NA motor.. so on and so on..
Old Mar 16, 2005 | 09:38 AM
Jeff92se's Avatar
I'm needing a caw
Looks like tuning from here. How's your knock sensor and crank/cam angle sensors doing?
Some have reported that the JWT ecu is a little fat on the A/F. Maybe consider a SAFC and do a bit of diy tuning with someone with a wideband. There might be another 5-10hp hidden in there.
Seafoam!
Old Mar 16, 2005 | 09:39 AM
2 Da Max's Avatar
headers for sure, and what about an afc controller? btw got any more vids from the track?
Old Mar 16, 2005 | 09:40 AM
VQuick's Avatar
Chassis Freak
Technafit stainless-steel clutch line, $25 through group deal. Makes a noticeable difference.
Old Mar 16, 2005 | 09:45 AM
chenzarino's Avatar
LSD for sure....I have a Vitek if you're interested PM me with your e-mail address and i'll send u pics.
Old Mar 16, 2005 | 09:48 AM
brad kay
MEVI (! Finally !)
JWT ECU
Stillen B-Pipe
Stillen Y-pipe
Stillen Muffler
Eibach Springs
K+N Air Filtering
NGK Copper plugs
Hyper-Grounding Kit
Short Throw Shifter
just wondering with all these mods have you dynoed it? and whats your 1/4 times and trap speeds?
Old Mar 16, 2005 | 09:55 AM
tslrock514's Avatar
IF it is between nitrous and a turbo/supercharger....go with the forced induction.ALL the way
James92SE
142
Jan 2, 2024 09:23 AM
BrandonCause
Sep 14, 2015 10:41 PM
thenewguyy
Sep 12, 2015 11:12 AM
