Fog light advice
Old Feb 19, 2005 | 10:48 PM
all4isu's Avatar
Fog light advice
hey looking to get some fog lights for my 97. where is the best place? how hard are they to install and is there a right up on installing them?(couldn't find one anywhere). they seem way too expensive for just fog lights from the sites ive found( around 150 or so for both) any help? thanks
Old Feb 19, 2005 | 10:53 PM
Mr.Duck's Avatar
im pretty sure there is a write up somewhere.. just look around, im too tired to search, look for oem ones in the classifieds
Old Feb 20, 2005 | 12:21 AM
DAVE Sz's Avatar
Hooooooonda.....
My advice, skip the OEM fogs. Get some round angel eye fogs from ebay. They look great if you mount them further back in the holes. I have 2 sets of OEM fogs from a 96. I'm planning on selling those and just buying some off ebay.
Old Feb 20, 2005 | 06:04 AM
|Bijan|'s Avatar
UCF Lexus
Try the group deals forum.
Old Feb 20, 2005 | 06:14 AM
hiphipmaxima's Avatar
all maxima's 95-99 are wired for fog lights
if your car doesn’t have fog lights all that’s involved in installing them is:
1) cut out the bumper (if not already done)
2) bolt on bracket
3) plug fog lights in
4) bolt the fog light on
5) install a relay in the left fuse box
6) buy and install headlight switch with fog light switch on it
Old Feb 20, 2005 | 06:16 AM
JetBlackMax83's Avatar
Hey Dave my drivers side fog is cracked wondering if you would sell me just one. if not how much for the set?
Old Feb 20, 2005 | 06:17 AM
items needed: fog lights brackets side pieces bolts relay and intermitted headlight fog light switch
tools needed: screw driver 10 mm socket
steps of install: 1995 1996
1) 1st you are going to use a dermal with a cut off wheel disc
2) next you are going to cut the bumper away cut right around the bumps on the fog light space you can always cut to little than to cut too much
3) 3 10mm bolts, bolt on brackets
4) next pop in fog lights you will be test fitting the fog lights around the bumper
5) trim the bumper is needed
6) when everything fits sand and use touch up paint on the edge where you cut.
7) slide fog lights into bracket and holder
8) pug fog lights in ( all maxima are prewired)
9) install 1 10mm bolt to hold fog light
10) pop side piece in
11) you are all done down there
12) next install a blue relay in the left relay box you can buy this relay at a pats store ~ $5.00 it is the same relay as the horn relay
13) next you will have to buy a intermitted headlight fog light switch
14) you can get it off ebay for about 25 or at a local junkyard
15) remove 6 screws from trim around steering wheel
16) remove 2 screws from headlight switch and unplug 2 wire harnesses
17) plug in the 2 harasses you unplug and there will he a 3rd harness a smaller one that you will have to plug into the new switch
18) reinstall everything and you are all done
Old Feb 20, 2005 | 06:18 AM
hey guys check out my thred im selling maxima fog lights 95 and 96
97 98 99 complete kits http://forums.maxima.org/showthread.php?t=379662
The Frye
Sep 2, 2021 11:03 AM
mvm062
Nov 30, 2020 09:00 AM
Maxima30
Sep 7, 2015 06:13 PM
Johnny9595
Sep 3, 2015 05:18 AM
