Is it normal for a maxima to vibrate?
Old May 1, 2001 | 04:17 PM
Faith
On my roadtrip this weekend I noticed that my steering wheel and my car start to vibrate at about 80mph. I don't remember it ever doing that. You think it might be time for new shocks? Could it be the timing chain. I have no clue why it's vibrating so much. If you have any insights to share I'd appreciate it.
Old May 1, 2001 | 04:21 PM
duplex's Avatar
Check your tire pressure, if you want a nicer smoother ride lowe the PSI to the standard 29 (depending on your wheel package). Also, I had teh same problem, and alignment did it! Do a free alignment check, and if its bad, thats your problem. i dont think its shocks or springs, usually =the shaking isnt suspension.
gluck!
Old May 1, 2001 | 04:22 PM
Justin95SE's Avatar
mine does that too around 80 mph
maybe tires need balancing?
Old May 1, 2001 | 04:25 PM
duplex's Avatar
yEA I DID balancing as well, and that helped!
NickStam's Avatar
Re: mine does that too around 80 mph
could be the road surface.
Old May 1, 2001 | 04:32 PM
Daniel B. Martin's Avatar
The usual symptom of a bad timing chain is an unpleasant rattle or clatter sound from the engine, most noticeable on first starting. Your symptoms are more likely to come from tires which are out of balance or out of round.
Old May 1, 2001 | 05:33 PM
deezo's Avatar
Make sure the mechanic uses an criss-cross pattern when putting your lugs back on. I had my tires balanced and I was still getting vibration. When I went to rotate my tires, I couldn't get the front-left tire off. I literally had to kick the tire off of the hub. The knucklehead used an impact wrench and also didn't use a criss-cross pattern which locked the wheel onto the hub unevenly.
acw
Aug 13, 2015 12:50 AM
altome15
Aug 10, 2015 07:05 PM
MikesChevelle
Aug 10, 2015 10:53 AM
rhonster
Aug 6, 2015 05:46 PM
