Headlight problem 96 SE
Old Feb 22, 2005 | 08:47 AM
Gilly1's Avatar
Wondering if anyone else had this problem. Left headlight went out but i checked the fuse and bulb and they are both ok! Any ideas??
Old Feb 22, 2005 | 10:18 AM
maxima2fly's Avatar
get electric tester and check on each wire .if non of them work i think you added the wrong bulb u need to slice and buy a new 9004
Old Feb 22, 2005 | 11:24 AM
Gilly1's Avatar
i reversed the bulb (i.e. stuck the right headlight bulb in the left headlight) and it didn't work so it's not the bulb 'cuz the bulb works on the right. Guess i'll get the wires checked!
Old Feb 22, 2005 | 11:29 AM
2 Da Max's Avatar
it might be the harness
Old Feb 22, 2005 | 11:31 AM
mbandi's Avatar
Da'Burgh, Go Stillers!
Your headlight connector has probably started to melt. This often happens if you are using a higher wattage bulb. You may need to splice in a repair end for a 9004 bulb. $5.00 at an auto parts store.
Old Feb 22, 2005 | 02:03 PM
Black Maxima
Hit the light with your hand HARD a couple times. That's what I did the night I got my Maxima. It' never went out since. Or you could try wiggling it a little bit.
Old Feb 22, 2005 | 04:51 PM
nismos14's Avatar
§è~® f®ÈÄk
check to see taht all the prongs on the bulb are making contact with the connectors on the harness, that sometimes fixes it for me
AaronL
Nov 15, 2020 11:52 AM
MaxLife17
Jun 27, 2019 01:37 PM
03VQMAX
Nov 10, 2015 03:39 PM
Vistance
Sep 17, 2015 05:17 AM
mpbclutch33
Sep 8, 2015 06:21 PM
