chaning my oil in about an hour
Old Feb 22, 2005 | 10:45 AM
  #41
Loe max's Avatar
Originally Posted by DragonMaxima
Question: I've seen this posted many times but don't know what it means-
10 char?
You are required to have a minimum of 10 characters (letters) to post something.
Old Feb 22, 2005 | 10:46 AM
  #42
Caracicatriz's Avatar
What was that?
Originally Posted by Jeff92se
Anything else I should do? ie.. engine swaps, 5-sp swap etc?.........
I'de go for the RB26DETT conversion. It's the easiest to do, and you can say you drive a skyline. Oh, and also a true dual exhaust. Ninos said it will fit, and since he is an expert, it must be true.
  #43
2 Da Max's Avatar
make sure you eat something kosher because our maximas tend to act funny when you eat other things.
  #44
Loe max's Avatar
pop in a Brittney Spears CD, it helps compress the air better
Old Feb 22, 2005 | 10:47 AM
  #45
2 Da Max's Avatar
in an hour? shiet if you hurry up maybe youll see exit10 change his oil too.
no offense exit10 just joking around
  #46
Jeff92se's Avatar
I'm needing a caw
Don't worry about it.
Originally Posted by tzmanles
i was only playin...lol, I guess I should have put that in huh?
Old Feb 22, 2005 | 10:50 AM
  #47
Ceasars Chariot's Avatar
Old Maxima Legend
well, while you are down there you might want to take a coin and measure your tread, i do this daily and keep a log of my tire mileage. you could also make sure your wheel weights are still in place. with thousands of rotations sometimes they flick off or warp out. more hitch hikers go to the emergency room each year from loose wheel weights flying off and striking them, than dog bites, or road side accidents. So it pays to be cautious !
but yeah put that air back in, lots of people hit the dragways and let the air out of their tires and then drive around for miles not remembering to fill them back up.
Old Feb 22, 2005 | 10:51 AM
  #48
2 Da Max's Avatar
honestly exit10 clean your throttle body then change your oil, its not necessary to change tranny oil less the every 30k miles. you will feel a difference when you clean the tb though. it costs like what 3 dollars for the can?
Old Feb 22, 2005 | 10:53 AM
  #49
exit10's Avatar
yea ima go outside and do it right now. i have some carb cleaner in the garage. thanks 2damax
  #50
2 Da Max's Avatar
loll hey ceaser are you one of those ppl who let air out of your tires and drive around for miles?
  #51
|Bijan|'s Avatar
UCF Lexus
Old Feb 22, 2005 | 10:54 AM
  #52
96white's Avatar
Originally Posted by exit10
sry i jus woke up an im not even sitting in my chair to type. oh and i suck at spelling
Old Feb 22, 2005 | 10:55 AM
  #53
|Bijan|'s Avatar
UCF Lexus
What is the forum coming to.....
  #54
2 Da Max's Avatar
btw jeff are you still mad at me for posting my incorrect info about the engine reving with no load is bad?
Old Feb 22, 2005 | 10:57 AM
  #55
exit10's Avatar
hahahah im glad i made the post rate higher. its all good though this is pretty funny. i dk what was going through my mind when i posted that. mabey cuz i think about my car the second i wake up and what needs to be taken care of. so basically i drank way to much beer last night and in my hangover this morning i slowly stumbled over to my computer and started typing random BS about sea foam and what not.
  #56
96white's Avatar
Old Feb 22, 2005 | 10:59 AM
  #57
Nismo3112's Avatar
Custom User Title
A Maxima making it to lunch and back?
I call
Old Feb 22, 2005 | 11:06 AM
  #58
deezo's Avatar
It would help that if you had wheels and tires on your car before you went down there, it would make putting air in your tires a very easy task.
Old Feb 22, 2005 | 12:24 PM
  #59
Nismotic's Avatar
Always sunny in philly
You must test out the oil to see if its purified. The best method is "the doing donuts and hitting into the sidewalk" method. That should be followed by about 15 threads. :
Old Feb 22, 2005 | 01:01 PM
  #60
DAVE Sz's Avatar
Hooooooonda.....
don't use carb cleaner dork, it will eat away at your valve clearance and your pushrods won't be able to push your rockers, seriously though, don't use carb cleaner.
Old Feb 22, 2005 | 05:47 PM
  #61
exit10's Avatar
allright now i know for next time. what should i get instead
Old Feb 22, 2005 | 05:50 PM
  #62
deezo's Avatar
Johnson rods should replace the pushrods.
Old Feb 22, 2005 | 05:52 PM
  #63
maxima_kenny96's Avatar
sea foam, change oil, clean your TB. easy enough.
Old Feb 22, 2005 | 05:53 PM
  #64
sryth's Avatar
What a fine replacement for the OT forum you've all made
Old Feb 22, 2005 | 06:20 PM
  #65
2 Da Max's Avatar
air freshner, and put some coolant in that clear platic container all the way on the bottom left of the enginebay
tarun900
19
Dec 20, 2021 06:57 PM
D Mason
Jun 21, 2016 04:43 AM
05RLS2
Apr 14, 2016 11:49 AM
mpbclutch33
Dec 26, 2015 11:11 AM
RealityCheck
Oct 2, 2015 06:34 PM
