would I be needing a camber kit?
Old Feb 24, 2005 | 11:01 PM
9maximuz8's Avatar
hey guys
do think ill be needing a camber kit with this setup: KYB AGX w/ Tein S.Tech 2.2F/1.8R
thanks
Old Feb 24, 2005 | 11:30 PM
BuNGsVQ's Avatar
yes 123456
Old Feb 24, 2005 | 11:40 PM
SFMax415's Avatar
definally i got agx w/ sprints 2.0 all around my front wheels are like this / ----- \ really bad...
Old Feb 25, 2005 | 05:14 AM
browne's Avatar
im getting eibach pro (1.5f - 1.3r) and someone here told me i wont need the camber kit, just a wheel alignment.
Old Feb 25, 2005 | 07:50 AM
Imobejoas's Avatar
eibach's drop is not as agressive as the sprint's. you shouldn't need a camber kit. get an alignment and if it's really bad then get a camber kit. it's not too expensive.
Old Feb 25, 2005 | 08:18 AM
nismomax98's Avatar
anything over a 1.6" drop will need camber ajust. found out the hard way my tires were shot in front mostly
Old Feb 25, 2005 | 08:29 AM
GodFather's Avatar
Made in Taiwan
well, i think everything over 1.8 drop in the front will need the camber kit.
we got 4 4th gen maxima's in my garage. two of them are dropped. one is with aerospeed/tokico blue 2" even drop combo. the other is h&r/kyb gr2 1.8" even drop combo. the 2" aerospeed dropped car cannot get aligned correctly. it need an addtional adjustment of about 1.3 degrees. the 1.8" h&r drop aligns correctly and had no problems. we just recently bought the tein s tech / tokico blues, and we also bought the eibach camber kit to install along.
i can assure you that you are going to need the camber kit to do the alignment after the tein s tech drop. take my word for it...
Old Feb 25, 2005 | 08:40 AM
GoalieKeg's Avatar
Do yourself a favor, and get a camber kit. I wasted a complete set of tires in 2 weeks from a coilover drop without camber bolts.
Old Feb 25, 2005 | 09:02 AM
bravehart's Avatar
Guess I got lucky. Tein S Tech with KYB AGX-front & GR-2 in rear. I never got camber bolts because it is so hard to find someone to a good alignment. I live in Snellville. 20K later tires are slightly more worn on the inside but definetely acceptable.
Old Feb 25, 2005 | 09:19 AM
Maximus_95's Avatar
my car is really really low right now with the Tein Coilovers, and i took it to the guy who does my alignment, and he aligned it to specs without having any camber kits.
i've been driving on 235/40/17's for about 2 years now and im guessing that i may be able to squeeze another year out of my tires. I drive about 12-13k a year. =)
Old Feb 25, 2005 | 10:49 AM
Nismo3112's Avatar
Custom User Title
I have agx/sprint on my car, and I DEFINANTLY needed a camber kit.. /___\ is the right description of what my tires looked like before the kit.
Old Feb 25, 2005 | 10:51 AM
1FSTMAX's Avatar
No... im lower than 2.2" and my camber is within spec.. i have no camber bolts or plates..
Old Feb 25, 2005 | 11:20 AM
96ItaliaSE's Avatar
il massimi bassi
I have camber bolts and tien s + agx....no alignment shop wants to tinker with it...the last place only set the toe
Old Feb 25, 2005 | 12:11 PM
GodFather's Avatar
Made in Taiwan
well, for those who got lucky to get within specs, congrats. but seriously, do yourself a favor getting a camber kit to make sure everything to be within the specs in the least tolerance level. mine was off 1.3 degrees and the guys tinkered with it so much and it was still impossible to correct it. the camber adjustment never drop to green from the red zones. camber kit will assure you to fix the problem, why not?
also, it appeared to me that guys with kyb struts are having less alignment problem than those with tokico's. is there really a difference? we need to find out for sure. my brother's max with a 1.8" drop and kyb gr2 combo does it just right. he said his alignment was done good and within specs. hm, that makes me wonder.
Old Feb 25, 2005 | 01:53 PM
Maximus_95's Avatar
well the shop where i got my alignment done, he is always doing race cars on weekends and basic cars on weekdays, and trust me, this shop knows what they are doing. All my friends get their cars aligned there and he does a great job. I guess it all depends on who you take it to get it aligned, but all i can say is that my tires are all worn evenly and i have been riding on them for a while now.
Old Feb 25, 2005 | 02:11 PM
lex4style's Avatar
hmmm thats weird...I have AGX w/sprints. And its almost been one year and I have lots of tread left and its wearing evenly. I should have atleast another
1 year on these tires. Never knew u needed a chamber kit for 2" drop. Oh well...
Old Feb 25, 2005 | 02:52 PM
Maximus_95's Avatar
Thank God our cars dont camber as bad as honda's!
Old Feb 25, 2005 | 05:45 PM
z32drifter's Avatar
Well I must have been lucky too..... -1.0 and -.9 with KYB and AGX setup.... when I installed the suspension..... I pulled down on the hub as I tightened the bolts thru the struts.... doing that ensured all the slack in the bolt holes were set to the positive side of the camber curve.... I put the car on the alignment rack and set the toe... drove the car 2-3 weeks and rechecked the alignment..... everything was still good
Old Feb 25, 2005 | 07:24 PM
RA030726's Avatar
I'm nutty for Nissans
you can always enlarge one of the bolt holes in the strut. I can never remember which one.
Old Feb 26, 2005 | 12:30 AM
9maximuz8's Avatar
where should i get a camber kit from for a good price and good quality?
Old Feb 26, 2005 | 07:00 AM
maximabebe's Avatar
What are our options for camber kits/plates/bolts? I know Stillen makes some overprices plates, but would that correct our problem? I have a set of camber bolts here (never installed) to pair up with my Tokico/Sprints. I recently bought Tein Basic damper coilovers and will be installing them within a month along with 19x8.5" wheels. So my question is.....with my new suspension setup will I need a camber kit and if so what kind? Any input is welcome.
Old Feb 26, 2005 | 08:03 AM
lex4style's Avatar
well personaly i mean im on 18's and sprints and i dont use any chamber kits. But if you got tein coilovers and ur gonna drop lower then 2" then id get a chamber kit. If your installing tein coilovers get a tein chamber kit.
Old Feb 26, 2005 | 08:16 AM
GodFather's Avatar
Made in Taiwan
i don't know who manufacture these camber kits out there, but recently i just bought two sets of eibach camber adjustment kit from the ebay auctions. when they arrive, i'll let you guys know how are they.
the two eibach kits cost me a total of around 60 dollars shipped. i think this is a good deal...
Old Feb 26, 2005 | 04:42 PM
9maximuz8's Avatar
would this kit do for my setup KYB AGX w/ Tein S.Tech 2.2F/1.8R
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WD1V
Old Feb 26, 2005 | 05:12 PM
GoalieKeg's Avatar
Go to http://maxmods.dyndns.org and check out the Camber kits that they have in the suspension section. Look into the Ingalls camber kit. It's a 4-bolt kit that adjusts up to 2.00 degrees. That's all you need, and it's only 50 bucks shipped.
maxprivate
Forced Induction
21
Jul 8, 2017 09:48 AM
smplyamzng
Dec 13, 2015 01:19 PM
SmokinMax02
18
Sep 11, 2015 12:25 AM
TonyJr
Aug 20, 2015 12:14 AM
carlosvq30
Aug 17, 2015 11:32 AM
