To get lsd posi or non lsd
Old Mar 2, 2005 | 04:18 PM
Maxima_Joe's Avatar
4th Gen Parts King
I have been contemplating getting a lsd,non lsd, or custom posi trans when i get my auto fully built.Things i would probably do are vb mod,2500 stall tc maybe stronger clutches.
I'm looking for a quick 1/4 mile and street car that is still a daily driver.While doing my research i have come across some information that i will be slower in the 1/4 with the posi.I'm assuming this is because i'm losing power becsause it's going to two wheels instead of one.But on the other hand i would think i would be faster with a posi if tracion was a problem.Also i don't know how driveable it will be on the street with the posi
With a lsd traction would also be better but i don't know if i would be slower in the 1/4.On the streets i think this one is my best option.
Non lsd we all know traction is a problem but it seems the best 1/4 times or with non lsd.
So what do all the maxima.org experts think.
Old Mar 5, 2005 | 10:39 PM
Maxima_Joe's Avatar
4th Gen Parts King
so where are the tranny experts?
Old Mar 5, 2005 | 11:04 PM
MDeezy's Avatar
Hopefully someone can correct me if I'm wrong but a LSD isnt going to gain more time in the 1/4 mile. Ok maybe help with traction off the lauch but very little.
**warning** I'm sure you get lot of "do a 5-speed swaps** remarks.
Old Mar 6, 2005 | 06:00 AM
mzmtg's Avatar
Minister of Silly Walks
The best quarter miles times are with non-LSD units because almost no one has an LSD trans in their car.
That said, if 1/4 mile times are your priority, I wouldn't stress too much about the LSD. At the power level most of us are putting down, it's not much of an issue.
Old Mar 6, 2005 | 05:19 PM
Maxima_Joe's Avatar
4th Gen Parts King
Well i have a slipping tranny now so i am looking to upgrade.I'm sticken with an auto i know theres alot of automagic haters.I think i am going to go with a 2000 ae trans which is lsd and beef that up.Is there any other opinions or why a shouldn't go lsd over non lsd?
Old Mar 6, 2005 | 05:26 PM
A Flood99's Avatar
just stick with the LSD, no need to build it up unless you're running boost
Old Mar 6, 2005 | 05:31 PM
Maxima_Joe's Avatar
4th Gen Parts King
I am planning on a 3.5 swap next winter.
Old Mar 6, 2005 | 05:51 PM
Vlasic's Avatar
RaWr!!! ('''_(o_O)_''')
im pretty sure the 3.5 trannys are different from the 3.0 ones. why would you get a built auto tranny and then 5 months later throw it away when you do a swap? why would you even waste your money on getting a built auto tranny instead of just doing a 5-speed conversion...autos are slow.
Old Mar 6, 2005 | 09:07 PM
Maxima_Joe's Avatar
4th Gen Parts King
well your wrong the trannys are the same. Thats also a very bold and inaccurate statment saying autos are slow.A built auto is not very much slower if any then a 5 speed.
Old Mar 6, 2005 | 09:22 PM
Vlasic's Avatar
sorry, i thought the 3.5 trannys were different then the 3.0.
how much will a built auto transmission cost?
Old Mar 6, 2005 | 11:45 PM
Maxima_Joe's Avatar
4th Gen Parts King
cost depends on what you want done.I figure anywhere from 1000 to 3500$.
I'm still debating what i want to do but i'm staying auto.
Old Mar 6, 2005 | 11:49 PM
Vlasic's Avatar
huh, i figured the cheapest it would be would be atleast $2500.
personally id take a clutch slipping, gear grinding manual over an auto any day. i dont want a car i cant have fun with...thats just me tho.
Old Mar 7, 2005 | 02:46 AM
Visitingreality's Avatar
Get manumatic. I have a manumatic, mobiletec stage 2 vb and hayden tranny cooler. The manumatic just makes it infinite better due to control, the vb/tranny cooler make the auto behave a lot more aggresivly.
Old Mar 7, 2005 | 02:57 AM
Ant96GLE's Avatar
For day to day drivability, its not going to make a difference. I think you are confusing that with welding the differential which is old school before LSD's were available or werent available or straight 1/4 cars.
Does it make a difference? Probably but not much. Unless you are making serious HP where you will be spinning only one tire most of the time, I wouldnt worry about getting it.
Old Mar 7, 2005 | 03:58 AM
Chickan's Avatar
I'll second that. Even if you can shave some time with an automatic, I'll still never buy one. Boring as snot to drive, never downshift right, yuck. Anything with a "park" gear can stay far away from my driveway.
That, and I'll never understand why anyone would buy a "built" automatic tranny, just blows my mind. Unless you have a Lingenfelter Corvette putting down 1100hp and turning a 1.9s 0-60mph time, I really don't see the need for an automatic transmission.
Also, even if you put in a 3.5L engine, why would you need a built tranny?
Old Mar 7, 2005 | 06:11 AM
TAPOUT's Avatar
You will lose
You would probably be best off to just build the tranny in your car. 2000's had lots of solenoid issues. If you are going to buy a new trans to build, get one from a 97-99 I30. It will have the traction you are looking for, and the drivability for the street. Some of the 99 Maxima's (mine),(Canadian models), also have the good auto. I love the way mine shifts with the Mobiletek VB. I shift it manually all the time, and run the snot out of it with nitrous, and have never had a problem with my trans.
Old Mar 7, 2005 | 07:42 PM
Maxima_Joe's Avatar
4th Gen Parts King
This is some good info i'm looking for i thought 2000 ae's had a stronger 3rd gear but was unaware of any solenoid issues. So there were no problems with 97-99 i30 or 99 canadian autos?
My cv joints are shot so i will have to replace my axles and my tranny slips so thats why i'm looking at a factory lsd.Its going to cost the same getting mine rebuilt or buying a used lsd unit that won't need a rebuild.
I would consider the posi unit welding the differential which would affect drivability.
Pied
Sep 26, 2015 03:29 PM
ef9
Aug 14, 2015 03:03 PM
Supragte
Aug 12, 2015 10:00 PM
bert
25
Jan 27, 2013 08:38 PM
ericdwong
Sep 9, 2001 08:51 PM
