Help Ecu Giving Weird Code
Old Mar 2, 2005 | 08:07 PM
SiCkBLaCKMaX99's Avatar
I ran the diagnostic check which i had to do diffrently then norm to pull the code my service light blinked 3 slow and then 4 fast does anyone know what code is???
Old Mar 2, 2005 | 08:16 PM
adithius's Avatar
(from stickies)
0304
Diagnostic Trouble Code 0304 points to a problem with the Knock Sensor. The KS is attached to the cylinder block. It senses engine knocking using a piezoelectric element. A knocking vibration from the cylinder block is senses as vibrational pressure. This pressure is converted into a voltage signal and sent to the Engine Control Module (The computer).
This malfunction is detected when an excessively high or low voltage from the KS is entered to the ECM. Possible causes include...
- the harness or connector (The KS circuit is open or shorted).
- the KS
The KS may be checked with an ohmmeter.
1) Raise the hood. View the engine from the driver's fender. Look into
the deep valley between the cylinder banks and below the intake manifold.
Identify the KS as a black item fastened to the block by a single vertical
bolt. A wire harness wrapped in black leads toward you, out of the valley.
That is the KS sub-harness.
2) Follow the KS sub-harness to it's nearest connector. This is connector F121.
It is located near the upper right-hand corner of the valve cover of the forward cylinder bank, as viewed from the front of the car.
3) Disconnect F121. You have to do a "press the latch and wiggle and
pull" to disconnect it. F121 has only two pins; if you see more than two
pins, you have the wrong connector. Use a digital ohmmeter capable of
measuring more than 10 Megohms. You want to measure the pins of F121, not
the sockets of the matching connector. Measure the resistance between a
good ground (such as the battery negative terminal) and pin #2 of connector
F121. On my car this is the highest of the two pins, the one closest to
the front of the car. The factory spec is 500 - 620 Kohms.
The manual says you have to remove the intake manifold to replace the KS. However, I think that a person with good dexterity and a 10mm ratcheting box wrench could replace the KS without disturbing the manifold.
Important note: the dealer can do a more thorough test with his CONSULT electronic tester. The resistance test described here is a useful but limited test. A Knock Sensor which fails this test is definitely bad. However, a KS which passes this test is not guaranteed to be good.
Old Mar 2, 2005 | 08:18 PM
MaDMvD's Avatar
According to the "ECU Decoder", http://vbxmaxima.8m.com/ecudecoder.html, looks like you have a faulty knock sensor - not something uncommon in 4th Gen Maximas, apparently. I'm not sure how much knock sensors run, but there is one on eBay selling for $95.00 shipped. If you're interested, http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW. BTW, there are several write-ups on how to DIY. I'm sure they're in the stickes. Good luck and keep us posted!
Old Mar 3, 2005 | 12:32 AM
Maximus_95's Avatar
uhmm....stickies buddy. if you dont want to get flamed.
Mar 12, 2020 12:06 AM
gustavison
Oct 4, 2015 06:50 PM
220k+ A32
Sep 22, 2015 03:08 PM
QueensMAX
Sep 15, 2015 04:14 AM
NissanNismoZ
Sep 12, 2015 07:30 AM
