Failed emisions today need help
Old Mar 5, 2005 | 09:25 AM
davemax's Avatar
I went to renew my inspection sticker today and it failed emisions.
I had codes 0705, 0111 & 0807.
What do I need to replace to pass emisions.
Old Mar 5, 2005 | 09:42 AM
BigLou93SE's Avatar
Depending on whether or not you failed because you had codes stored, I'd say fix them all
If your question is what these codes mean, look in the 4th gen. faq's, they have a list of the codes and what they mean
Old Mar 5, 2005 | 09:54 AM
davemax's Avatar
Well i checked the codes before the test then I reset the computer. I was this would alow it to pass.
I also read the Haynes book and it realy doesn't say much. I just want to replacve the peice that was causing the problem. I don't want to pay dealer rates. Any write ups on this issue. I have a 97 maxima and the evap sytem is in the back.
Old Mar 5, 2005 | 10:14 AM
DAVE Sz's Avatar
Hooooooonda.....
Your car failed cause you reset the ECU right before the test, what did you expect? The ECU wasn't ready and you failed.
Old Mar 5, 2005 | 11:51 AM
cam_honestiam's Avatar
You need to drive between 150 and 200 miles for the ECU to fully reset itself and run all of its tests. The EVAP problem is notorious for giving heck on fourth generations...no suggestions...
howardis
Dec 11, 2019 06:10 PM
Forge277
Jun 13, 2016 09:26 PM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
