FSTB Installation Problem.. :[
Old Mar 5, 2005 | 11:21 AM
MaDMvD's Avatar
Please, be easy on me.. My FSTB just arrived this morning, and I rushed to install it. I was able to get 2 of the nuts off in each side, but 2 of them won't even budge. I read that the car should be on a flat surface when installing a FSTB, and it is. I torqued those nuts so bad they don't even look hexagonal anymore, but rather a strange mix between an octagon and a circle...lol. Any ideas on how I can get those last 2 off? Do I need to jack up the car or something? I'm extremely frustrated as I thought this should be a 5 minute thing, and it's been about an hour now. Please help!
Old Mar 5, 2005 | 12:02 PM
tavarish's Avatar
fwd gone rwd cr00
you've stripped the bolts....use a vice-grip and some anti-seize or wd40 to get them off....
Old Mar 5, 2005 | 12:19 PM
sunten1
next time make sure you use the right socket - look below
Old Mar 5, 2005 | 12:24 PM
njmaxseltd's Avatar
14mm 6 point socket for 95 - 98, and 22mm 6 point for the 99.
Old Mar 5, 2005 | 01:14 PM
adithius's Avatar
Always get the right tools before working!
You dont have to raise the car. Use penetrating oil. Try hammering the bolt a bit to get some of the rust out. Use a six point wrench or socket. If that fails use a vice grip. If that fails, you have to get a bolt extractor.
You should probalby get replace the bolts when you get the old ones off. Rounded bolts=YUK
Good luck.
Old Mar 5, 2005 | 01:29 PM
MDeezy's Avatar
Good luck.
maan thats the truth, stripped a drain plug trying to get it off, vise-grip couldnt even get it off. . .
yea try WD-40/ some heat/ and/orvise-grip
Old Mar 5, 2005 | 01:57 PM
joosdawg's Avatar
o man if you just would have used a breaker bar and the correct socket you would have had those all off in less than 2 min -Ryan
Old Mar 5, 2005 | 03:34 PM
ThurzNite's Avatar
will heating it up help?
Jae
Old Mar 5, 2005 | 04:02 PM
Kinger402's Avatar
Same thing happened to me. Mine stripped and i was even using a 6 point 14mm...those things rust on after being on for ten years....Just goto the dealer and order the nuts they were like .80 cents a piece. I just replaced all 6 of mine even tho only one got stripped. The way I got it off was using a tool i got at sears Its called a craftsman Bolt Out kit. Heres the link http://www.sears.com/sr/javasr/produ...id=00952160000
Old Mar 5, 2005 | 04:11 PM
Black Maxima
I'm real weak. I used penetration oil, the correct MERTIC socket, and a breaker bar. I got the nuts off without any problem.
And then torqued them to 30 ft. lbs. with a torque wrench.
Old Mar 5, 2005 | 07:17 PM
MaDMvD's Avatar
Thank you guys for all the helpful replies. I was able to get another one off, but there's still one rounded one left on the driver's side. I went to Sears and got a 55 piece Craftsman socket wrench set, with a load of other goodies for only $29.99. I guess I'll try some WD40 tomorrow, and if that fails I'll try getting that bolt extractor set. Thanks again guys, I'll keep you posted
Old Mar 5, 2005 | 08:24 PM
joosdawg's Avatar
you can also just get the sockets that have groves inside that are specifically for taking out rusted or rounded bolts there AWSOME there at home depot in a little blue container with yellow writing if that helps but it got every round bolt out for me
Old Mar 5, 2005 | 09:42 PM
ThurzNite's Avatar
is wd40 a penetrating oil?
Jae
Old Mar 5, 2005 | 10:29 PM
MDeezy's Avatar
it will help break a bolt free but I dont think its a penetrating oil. but I'm not too sure.
Old Mar 6, 2005 | 07:02 AM
Black Maxima
Penetration oil works a lot better than WD-40. It is made for loosening nuts and bolts, where WD-40 has a lot of uses.
MaxLife17
Jun 27, 2019 01:37 PM
Excalibur23
Oct 13, 2015 04:33 PM
Max8
Sep 22, 2015 02:53 PM
2kmaximel
Sep 16, 2015 03:19 PM
Maxxx10
Sep 13, 2015 03:16 PM
