good invention for someone to undertake...
Old Mar 6, 2005 | 01:03 PM
Stuntin' 101's Avatar
had a good idea for some of the project oriented people in here.. i know some of you guys are electronics freaks so this might be a pretty simple thing to do, and i think would defianetly stand to make some money.
come up with some kind of system to enable the driver to adjust his/her adjustable struts without having to leave the driver seat. mabye a servo system, or a few rotary type switches that can be mounted above or near the adjustment ***** for say a set of tokico illuminas. you can have it controled by a small master switch type brain or box that can mount under the dash, or even in the dash that can also give a digital display of what setting the struts are currently in, and a way to just hit a button to adjust them to a softer or stiffer setting on the fly. mabye even adjust the front/rear independtly with a seperate display for each. just a thought, cause i know if get adjustable struts, id love to be able to just hit a switch to make them stiffer when i get onto the highway, and softer as soon as i get off without having to pull over, stop, and get out every time i got on or off.. anyone else agree??
Old Mar 6, 2005 | 01:15 PM
seanwn's Avatar
this is a good idea. i used to be into 4wheeling and i know rancho has a product like that, it sits in your cab and you can adjust the front and rear seperately.
http://www.gorancho.com/products/acc.../RS9000RCX.stm
Old Mar 6, 2005 | 01:54 PM
some one has got to come up this for illumina set-up... i bet tokico would even work with someone to design this. i would persue this further but i have no enegry. too many other things going on, so ill give it away..
Old Mar 6, 2005 | 02:01 PM
RA030726's Avatar
I'm nutty for Nissans
its called Tein EDFC
Old Mar 6, 2005 | 02:27 PM
not compatiable with 4th gen maximas, and has to be used with their own struts from what i just read. but, does prove to be a very marketable product..
Old Mar 6, 2005 | 03:08 PM
Torgus's Avatar
uhh.
it's been done before.
actually it was stock on a car in the 80s. no super car either. only availible in europe tho =[
also the cost would be outrageous for an aftermarket company to do this for the 4th gen maxima. you'll see it on civics long before you'd ever see it on a 4th gen.
nice idea tho.
just not original.
Old Mar 6, 2005 | 03:31 PM
Akumachan's Avatar
I never narc'd on nobody.
he never said it was new to the automotive industry, but it most certainly is new to 4th gen maxs (thats what forum we're in too!) i personally wouldnt mind having that option, but im going with d2 coilovers, so it would have to be different. 36way adjustable, not just 5. in anycase, good idea, and maybe someone will make some.
Old Mar 6, 2005 | 04:09 PM
i bet there could be a way to modify the motors from that tein set up to work with our cars. i would imagine the only reason they wouldnt fit rite on, it just clearence issues for the fronts with the hood closed. they look like they mount above the strut, so i would say the backs would be fine, just an issue with the fronts. i wonder if you could mount those motors next to the strut bolts on the top of the wheel well up front, and have some kind of gear or friction wheel on the motor to turn the adjustment ****. control box wouldnt work with the illumina's though. it says the teins are 16/32 way adjustable
Old Mar 6, 2005 | 10:44 PM
bump.. cause i want somebody to make this so i can get it.. lol
Old Mar 6, 2005 | 10:53 PM
Originally Posted by Torgus
uhh.
nice idea tho.
just not original.
why would it be outrageous? the same thing im talking about is made for the tein setup that other kid posted, and there applications for 80+ cars, including the 5th gens, just not ours.. like i said, its probably just a clearence issue with the fronts for the 4th gen. granted there set up is a little expensive, but its also a much more complex system then the illuminas would need. theres has like 32 adjustments, programable memory.. blah blah blah.. we just need something to turn 4 ***** to five different settings at the same time. honestly, i wouldnt even care if you could hit all 5, cause people probably only use 2 MABYE 3 tops.. if that.. how many of you guys are jumping outta yoru car in to change them everyday ya know? at least with something like this you'll actually get some use out of the adjustments you paid to have with your struts..
Old Mar 7, 2005 | 01:35 AM
Supermax95's Avatar
If i remember correctly my 88 supra turbo came with an options called "TEMS" im pretty sure it toggles the suspension to be more sporty or softer...not 100 percent sure though as i was 16 and didnt know jack about cars when i had it.
Old Mar 7, 2005 | 02:52 AM
Ant96GLE's Avatar
While it is a good idea, going through all that trouble to develop something that could be cured by not being lazy isnt going to fly. That and most people will never touch the dials again when they find the right suspension setting.
The Frye
Sep 2, 2021 11:03 AM
MaxLife17
Jun 27, 2019 01:37 PM
MaxLife17
Sep 8, 2015 02:36 PM
Adoubi21
Dyno Discussion and Slips
Sep 7, 2015 09:34 AM
